November 2, 2018 at 4:48 pm
masud407
SubscriberI want to add the viscoelastic properties of muscle in ANSYS workbench. Can anyone give me insight about the procedure of adding viscoelastic properties in ANSYS workbench?
November 2, 2018 at 9:26 pm
Sandeep Medikonda
Ansys EmployeePlease take time to go over this section from the manual.
Hope this helps
Sandeep
Best Practices on the Student Community -
November 13, 2018 at 4:56 am
masud407
SubscriberHey Sandeep,
Thanks for sharing. However,your referred article just introduced the concept of viscoelasticity which may not help. I need to add the viscoelasticity of material. So what information should I need to insert? Should I need to fill up the table for prony shear relaxation and shear data-viscoelastic? Do I need to insert the initial shear modulus(Mu) and incompressibility parameter(D1) under neo-Hookean tab?
November 13, 2018 at 12:55 pm
SubscriberMasud,
Why do you want to use viscoelastic properties for muscle? What is the behavior that you want to add to your model? I know you are working on human body response to vibration coming through a seat. There is a lot you can do with Damping properties, without having to go to viscoelastic materials.
What range of times do you want the muscle to have appropriate viscoelastic properties? It is for just a few seconds, right? I say that because the properties that work well for a few seconds will give ridiculous results on the time scale of hours.
Peter -
November 13, 2018 at 6:23 pm
masud407
SubscriberHey Peter,
I am trying to use viscoelastic properties as I am not finding a constant value of young modulus for muscle . Also, a lot of works have been done to analyze the viscoelastic properties of muscle and mentioned muscle as viscoelastic material. Yes, i have to applying vibration maximum of 2 minutes time frame. I understand that you mentioned in the last line. But i am just trying to consider the muscle according to literature. So can you please tell me what information that I need to use to show the time variant elastic modulus for the viscoelastic muscle? Thanks.
November 15, 2018 at 8:48 pm
masud407
SubscriberIf I simulate it for maximum of 120 sec with a constant elastic modulus for maximum of 50 Hz, will it be significantly different than the result of using viscoelastic properties?
November 22, 2018 at 12:16 am
jonsys
SubscriberYou should insert the Shear Data (Shear Modulus-Time relation) and get the Prony Shear Relaxation coefficients by doing a curve fit.
This post will definitely help you how to do it because it has a lot of screenshots (there might be some additional information there about temperature and shift functions but don't focus on them because you don't need them).
Try it and come back with specific questions about which part are you struggling with
November 27, 2018 at 12:30 am
masud407
SubscriberHello Jonsys,
Thanks for your comment. After going through your post, I have some inquiry:
1) How should I insert shear modulus-time relation data? Isn't it the same as obtaining data from the equation of G(t)? or It's the value obtained from stress-relaxation data?
2) Should I include the properties of isotropic elastic properties?
3) for curve fitting, I changed the seed values. However, the curve (obtained from sdec-red marked) is not changing, in fact it's showing a straight line. What should I do to fit the curve?
Thanks for your time and effort. Looking forward to having your valuable reply.
November 30, 2018 at 7:10 pm
masud407
SubscriberAs I have seen that I have to add isotropic elastic properties to define the viscoelastic properties, Can you please tell me what should be the value of elastic modulus that I need to insert? Is it the same as the value of E(t) at time t=0?
November 13, 2020 at 4:34 pm
2066
1279
1096
457
