November 7, 2017 at 5:16 pm
momidor
SubscriberHi,
I would be very pleased if I'll able to add circa 1/16' red pointed "offset" which is encircled the crucial hole. I mean kind of inflation but it is doesn't work. Does someone can share how to do it
Regards
Mom
November 7, 2017 at 6:17 pm
SubscriberHi Mom,
I can't quite see the surface you are trying to inflate from the attached file, which I have included below.
A shaded rendering of the geometry might be easier to see. Is this a Mechanical or a CFD mesh?
I slice geometry in DesignModeler to get sweepable bodies that can easily be inflated such as this example of an airfoil.
Can you attach the geometry in Parsolid or other neutral file?
Cheers,
November 7, 2017 at 7:32 pm
momidor
SubscriberHi Peter,
This was attached as a "step" format.
November 7, 2017 at 8:55 pm
SubscriberOkay, can you attach that here? If not, attach it to an email to me and I will take a look.
November 9, 2017 at 12:46 am
November 9, 2017 at 7:40 pm
momidor
SubscriberThanks Peter !
November 14, 2017 at 10:04 pm
SubscriberHey momidor,
I compared inflation, which created wedge elements, with tetrahedral elements and learned that the tetrahedral elements converged on the exact value faster than the inflation layer elements. See this discussion.
August 14, 2018 at 8:35 pm
mekafime
SubscriberHello Peter,
in this case do you recommend Tet element for mesh?
August 14, 2018 at 9:57 pm
SubscriberYes mekafime, in this case, Tet elements converged on the exact solution with fewer elements than the Wedge elements.
But in another model, Hex elements might converge faster that Tet elements.
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5290
3311
2469
