April 21, 2018 at 4:26 pm
rrdbes
SubscriberHi everyone! I just did a 2D steady state analysis on the temperature and wind profile on a naturally ventilated greenhouse. Results were seemingly acceptable (See attached photo). However, i wanted to extend my simulation by adding plants or crops in the system (therefore adding new bodies, and the effect of evapotranspiration in the energy model), and adding shading nets.
For the shading nets, i am thinking to just add a thin surface body inside the structure and used the "via system coupling" for thermal boundary condition. However, i am really puzzle on how to add the effect of plant canopy on the air flow and energy balance.
Thanks a lot!
July 20, 2018 at 7:15 pm
mli
Ansys EmployeeRun the fluids model first before turn on system coupling.
- The topic ‘Additional Set Ups’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
