August 20, 2019 at 7:43 am
nawazkhan
SubscriberHi, I have encounter an issue on physics setup. Additional Walls on the boundary condition are added. Even if i have tried to display it. it can not. Also, A note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface.
Can anyone help me to sort out this problem please...
August 20, 2019 at 9:02 am
nawazkhan
Subscriberanyone please help....
August 20, 2019 at 10:06 am
Ansys EmployeeGiven time zones I'd suggest waiting for a day or so before bumping a thread: some of the ANSYS staff will still be in bed pre Monday start time, others think it's just turned Tuesday. Wait longer at weekends.
You've got a mesh interface, when these are created Fluent also adds a wall to prevent errors if the two (or more) zones don't fully overlap. These can't be displayed, and in most cases don't do anything.
August 21, 2019 at 3:50 am
nawazkhan
SubscriberDear Rwoolhou
Thanx for your reply but i am really confused about the implementation of boundary conditions in these extra walls as i dont what these walls are?
regards
Nawaz Khan
August 21, 2019 at 9:54 am
Ansys EmployeeYou have a mesh interface: open & display that. It may be you didn't use share topology or similar or the dimension was small enough for ANSYS Meshing to automatically create a connection.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1349
1118
461
