December 7, 2022 at 11:19 am
Basma_Eldosouky
SubscriberHello,
I add amesh in the simulation of a plasmonic structure using the following commands:
addmesh;
set("z", thick_Si/2 ) ;
set("z span",thick_Si+2.5*height_margin);
set("x min", Xmin+2*FDTD_above ) ;
set("x max",Xmax-2*FDTD_above);
set("y", 0 ); set("y span",Wg_2+2*width_margin);
set("override y mesh",1); set("override x mesh",1);
set("set equivalent index",1);
set("equivalent y index",3);
set("equivalent x index",3);
set("equivalent z index",3);
when changing the equivalent x, y and z index from 2 to 3, I get a significant change in the simulation results. why this happens? and what are the correct settings to get an accurate results? -
December 8, 2022 at 2:06 am
Kyle
Ansys EmployeeHello,
Plasmonic structures can require a fine mesh near the dielectric-metal interface. We recommend using convergence testing to determine the correct mesh size for a given level of accuracy: convergence testing
- Error on Lumerical device
2706
2142
1355
1144
462
