March 28, 2018 at 7:29 am
waquar
SubscriberWe are PhD students in IIT Kanpur, India. We have academic license of ANSYS.
In our problem, we are solving energy equation with source term. The problem requires to apply adiabatic heat flux with specified pressure at inlet. We found that there is no option to specify adiabatic heat flux with pressure inlet boundary type. Can you suggest about incorporating the above mentioned conditions?
Your response will be highly appreciated.
Thanks.
Regads,
Ankush Jaiswal and Waquar Raza
March 29, 2018 at 8:58 pm
Raef.Kobeissi
SubscriberHello,
At flow boundaries, you can use the incoming fluid temperature. Heat flux are only applied on walls. What's the source term you're trying to use? is it like a constant heat flux through the boundary?
Cheers
5324
3311
2471
