STEM
STEM
Adiabatic vs Isobaric
    • Keyur Kanade
      Hello, can anyone explain the difference between an adiabatic process and an isobaric process?
    • Karthik R
      Administrator
      Hello @kkanade
      A thermodynamic process in which no heat or mass transfer occurs between the system and surroundings is called an adiabatic process.
      On the contrary, a thermodynamic process in which no change in pressure occurs in the system is called an isobaric process.
      Does it answer your question?
    • Keyur Kanade
      Hi @kremella, that answers my question. Thank you!
