Adjoint Solver; Convergence of residuals
    • Aras karimi
      Hi everyone,
      I am optimizing a geometry using Fluent's adjoint solver. I manually optimized the geometry several times in the adjoint solver (manually means that I did not use the gradient-based optimizer And after finishing each iteration of optimization, I did not click the initialize option of the adjoint solver). In this case, the residuals of the adjoint solver converge well, which is as shown in the following figure:
      Because the optimization process is time-consuming and boring, I used the automatic optimization feature of this solver (Gradient Based Optimizer). But according to the figure below, the residuals do not converge well:
      It seems to be auto-initialized after each optimization iteration is completed, which makes convergence very difficult. Is there a way to disable auto-initialization of the adjoint solver during optimization ?
      Thanks in advance.
Viewing 0 reply threads
