ADJUST macro to get second derivatives of converged velocity field
    • uconcorde
      Hi Amine,
      I am trying to use ADJUST macro to get second derivatives of my converged velocity field, but I got all zero values. Here is the code and procedure I am using. Can you please help me to find any mistake I have?
      # include "udf.h"
      DEFINE_ADJUST(adjust_gradient,domain)
      Thread *t;
      cell_t c;
      face_t f;
      domain = Get_Domain(1);
      thread_loop_c(t,domain)
         begin_c_loop(c,t)
            C_UDSI(c,t,0) = C_DUDX(c,t); // calculate d2u/dx2
         end_c_loop(c,t)
      Procedure:
      1) Open my .cas file
      2) Interpreted udf
      3) Open my converged .dat file
      4) User defined -> Scalars -> 1 -> Solution Zones: all fluid zones; Flux Function: none; Unsteady Function: none
      5) Solving -> deselect User Scalar 0
      6) Run calculation for 1 time steps
      7) Check contour plot of User Defined Scalar: all zero values.
      Best,
      David
      I suspect the solver is clearing the gradient value before it's saved in the case. I'd have a look at UDM rather than UDS: there is a difference, and also check the options in the TUI  /solve/set/expert
      As an aside, please don't post into old threads which are marked as "solved": we don't tend to check in those!
