Preprocessing
Preprocessing
Adjust Mesh Setting can’t mesh
    • jk820912168
      Hello,Everyone
      I'm ansys beginner.
      Ansys Version: 17.2
      Model size:10.650 mm* 7.728 mm
      Have a small geometry in model,it's thickness 0.05 um.
      I try to slice my model,
      and adjust mesh setting,
      it can't mesh. Most of the time,the ansys window screen freezes.
      What's correct mesh setting for my model?
      Please help me,thanks!
    • Aniket
      I would suggest you to mesh the bodies sequentially one after another (by right-clicking on body> Generate mesh on selected body). This would be a manual process but you will be able to isolate the problematic body.
      Ansys staff can not download attachments on the student portal, so I can not download your model and debug at my end.
      Also it seems that you are using all default settings so that should not  be a problem.
      -Aniket
    • jk820912168
      Hi, Aniket
      Thank your reply.
      Actually,I've tried to your suggestion,mesh be successful.
      But slove show error,I think the error from mesh issue.
    • Aniket
      Please go to the solver output file and search for the error. Search the forum for that same error, if you do not find any useful posts, kindly start a new discussion under structural mechanics.
      This is a niche application within Mechanical so please be patient someone will be reply to there.
      Thanks for your understaning.
      -Aniket
Viewing 3 reply threads
