January 22, 2021 at 2:51 am
YasserSelima
SubscriberHello,
I am trying to adjust the under relaxation factors between iterations. I am using RP_Set_Real in Define_Adjust to do this. I kept trying to access the under relaxation by
(%rpgetvar 'temperature/relax)
(%rpgetvar 'pressure/relax)
(%rpgetvar 'density/relax)
And it worked only for those three. Now I am trying with the momentum and I can't know its name. Does anyone know the name of momentum under relaxation? Or is there a way to list all the rp-variables in a report?
You help is appreciated
January 22, 2021 at 10:27 amDrAmine
Ansys EmployeeThere is no list of all rp-vars as those are intended for internal usage, actually.
We also do not recommend reducing relaxation factors at all without a system behind it. For your question: you might try mom/relax.
January 22, 2021 at 1:43 pmYasserSelima
Subscribermom/relax worked, thank you!
5028
3137
2369
1306
922
