October 2, 2023 at 9:23 am
100041488
SubscriberHi all,
I am creating an unstructured mesh using the watertight scheme in ANSYS Meshing, but I am having trouble adjusting the two adjacent boundary layers. Specifically, I would like to control the step transition between them. You can refer to the attached file for clarification. Currently, I only have four cells to work with, but I would like to have, for example, 10 or more. Does anyone know how to achieve this? (The geometry is that of a cylinder with external flow, and I am trying to adjust the boundary layers around the cylinder.)
Many thanks in advance and best regards.
October 3, 2023 at 3:55 am
100041488
SubscriberHi again,
I posted this question, but I haven't received a response yet. My issue is quite urgent, and I would greatly appreciate any assistance!!. Thank you in advance for your help. ?
Best regards
- License Error
- how to open DesignModeler
- FlexNet Licensing – Not running
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
- Numerical Problem Size limits with a model that should run
8758
4658
3151
1678
1456
