Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
ADPL comman snippet to replace SOLID186 element with CPT216 Element
    • Fraser Shields
      I'm trying to setup a biphasic analysis of a solid hydrogel reinforced with thermoplastic shell (sandwiched between the solid parts). I have run the initial solution with SOLID186 elements for the hydrogel and shell 281 elements for the shell. I want to use ADPL command snippets within the static structural tab in ANSYS mechanical. However, I am a bit stuck. I am trying to get model the fluid pressure in the hydrogel parts when the construct is placed under a compressive displacement of 20% strain.
      I have tried the following command snippet with no success:
      /PREP7
      ET,9991,CPT216
      ESEL, S, SOLID186
      EMODIF, ALL, TYPE, 9991
      /SOLU
      Any help would be much appreciated,
      Thanks
    • Rahul Kumbhar
      It seems ESEL command is wrong. It should be like: ESEL,S,ENAME, ,186
    • Dave Looman
      Also, add ALLSEL command after EMODIF.
    • Fraser Shields
      Thanks for the help, I've managed to improve my script slightly, however I am now running into an error "Element type 216 requires the definition of TB,PM with the activation of pressure DOF (KEYOPT(12)). ". My script is as follows:
      /PREP7
      ! Define an element type with the desired real constant (CPT216)
      ET, 9991, CPT216
      ! Select the solid elements you want to modify (SOLID186)
      ESEL, S, TYPE,, 13, 57
      ! Modify the selected elements to use the specified element type (9991)
      ! Define proelastic material for solid elements
      MP,EX,1,0.001 ! YOUNG'S MODULUS
      MP,NUXY,1,0.0 ! POISSON'S RATIO
      FPX=0.5 ! PERMEABILITY
      ONE=1.0
      TB,PM,1,,,PERM
      TBDATA,1,FPX,FPX,FPX
      TB,PM,1,,,BIOT ! BIOT COEFFICIENT
      TBDATA,1,ONE
      ! Define linear elastic material for shell elements
      MP,EX,2,0.1 ! YOUNG'S MODULUS
      MP,NUXY,2,0.0 ! POISSON'S RATIO
      ! Select the solid elements you want to modify and assign material 1
      ESEL, S, TYPE,, 9991
      MPCHG, 1, ALL
      ! Select the shell elements you want to modify and assign material 2
      ESEL, S, TYPE,, 1, 12
      MPCHG, 2, ALL
      ! Select all elements
      ESEL, ALL
      ! Continue with the solution phase
      /SOLU
Viewing 3 reply threads
