AFPM machine simulation 3D
    • hameed
      Sir,
      I m doing simulation
    • Karthik R
      Administrator
      Hello, nIt looks like @nchode, is engaging with you in this thread. Please respond here.n
      Hy I am working to simulate the axial flux permanent magnet machine i have design all the parameters of model and analyze the setup but the results are not according to standard i need pure sine wave having value in volts (5 to 10V)https://us.v-cdn.net/6032193/uploads/KENC7LM28TFB/15991150861822033420867.jpg with 90 degree phase shift in the induced voltage attaced figure has shape near to sine but value in mV i have set the mesh is ansoft classic and small analysis setup when i increase the setup size distortion in waves occurs. i have get flux linkage waves are accurate but the induced voltage have ripplesFigure are attached Please guideThanks ?https://forum.ansys.com/discussion/20043/not-getting-pure-sine-wave-and-volatage-magnitude
      Thank you.nKarthikn
