Discovery Import
Discovery Import
After launching “Discovery Live” shown attached graphic card error message under “Discovery Aim” window when desktop accessing thru Citrix
    • Sagar Patil
      Hi Ansys Support Team, We are facing application launching issue while handling office desktop access from Home thru Citix.   Some system working fine, but few system getting error message(attached). We have already checked  office system fully support as per application req. even work well from office. please do the needful to resolve it.
    • Sagar Patil
      1997706641 support request no
    • Charudatta Bandgar
      Hello SagarLive
      Looking at the screengrab, I can see that the graphic card drivers are not updated since almost 2 years. Can you please update them to the latest version from the manufacturer's website?
      Regards.
      • Sagar Patil
        hi Charudatta Bandgar , update graphics drivers but still getting the same error message while launching dsl. (image attached)
      • Sagar Patil
        SagarLive
        Even GPU1: Citrix display Only Adaptor drivers also updated.
      Hello SagarLive ,
      I had a discussion with the experts, according to them, this is likely has something to do with the Citrix being used to access the machine. Discovery requires a discrete hardware GPU and as you can see that GPU1 is a virtual one created by Citrix. This is probably confusing the software. What we can try is to go to the NVIDIA control panel on your machine and setting the CUDA and OpenGL rendering GPUs, both set to P4000. If this works and solves your issue please let me know.
      Regards.
      • Sagar Patil
        Charudatta Bandgar
        but with same case working fine with M2000 graphic card. Is there any specific setting need under Citrix or NVIDIA control panel for P4000?
        Ideally, there shouldn't be, SagarLive
        Maybe Citrix might confuse the software. I will try to find the exact reasons.
        Were you able to try to change it through the NVIDIA control panel?
        Regards.
      • Sagar Patil
        Charudatta Bandgar
        its resolved with trial & error method.
        Thanks a lot!
        Thanks for the update, SagarLive
        What exactly worked in our favor?
        Regards.
Viewing 3 reply threads
