June 29, 2022 at 1:46 pm
A.sanchai
SubscriberI created a geometry and assign material for each of them.But after meshing end of the cone is gone/ the material change from mat 1 to mat 2 ? I check Vlist shows negative value (-2) in material of volume 3,7 (are the end of cone).But I assign mat 1 for those regions, why it is changed?This is how I meshMeshtool>Element attributes: GlobalMesh: volumesShape: tet, freepick allError says: Mid-nodes of some elements have been modified to lie on straight edges because of distortion with the original mid-nodes. This condition is sometimes eliminated by tetrahedron element improvement when enabled. Issue ESEL,,STRAIGHTENED to select such elements for listing or plotting.Thank you! -
August 3, 2022 at 9:55 am
Ashish Khemka
Ansys EmployeeHi,
Try using the EMODIF command.
20 APDL Commands Every ANSYS Mechanical User Should Know - PADT (padtinc.com)
Ashish Khemka
- Maxwell, HFSS or Q3D?
- Error
3638
2502
1733
1226
578
