after meshing of 2d fluid surface starting problem of ansys fluent 15.0
    • skp123
      after starting fluent module
    • skp123
      this massage apper what will be the sloution please suggestmassage of failure of fluent
    • skp123
      it is full part of masage
    • skp123
      Please send me any suggestion how to over come this situation , i cant run ansys in my laptop system,
    • skp123
      this is the massage for  flent task comand page:
      ""Loading "C:PROGRA~1ANSYSI~1v150fluentfluent15.0.7libfl114-64.dmp"
      Unable to connect to external socket: Error during socket creation
      Opening output file:"SolutionResult.xml"
      Error: cx-run: can't listen on rendezvous socket.
      Error Object: ()
      Error: eval: unassigned variable
      Error Object: rp-3d?
      version>
      Interrupting...
      Done.
      version>
    • raul.raghav
      Can you try opening fluent after restarting your computer or disabling your internet? It seems to work for some people.
      If you could attach your workbench file, we could take a look into it. If you're not sure how to create and share a workbench archive file, please refer: Saving & sharing of Working project files in .wbpz format
      Additionally, you can install Ansys 19.0 Student version on your laptop to use the latest version of Fluent. Please refer: Ansys 19.0 Student Products
Viewing 5 reply threads
