August 28, 2018 at 12:01 am
AeroX
SubscriberHello to everyone,I've recently installed AIM on another computer.
In despite of the setting process going well,I can't run AIM when I'have to work with it.
The crushing error says that the workbench has stopped to work and after that Windows 10 automatic activity managment suggests me to stop the process,I don't really know if it's linked to some predefinited settings or to some errors during the installation,but I've tried anything on my own but I can't get out of it.
Can you help me?
August 28, 2018 at 2:10 pm
DrAmine
Ansys EmployeePlease elaborate more on the problem by telling us the specifications of your machine (OS, Graphic Card,..), the release you are trying to work with as well as a screenshot of the error message in AIM. Moreover can you check the installation log files and identify any error messages?
I will move this question to the installation and licensing thread.
August 28, 2018 at 2:39 pm
AeroX
SubscriberThank you very much!
I'm tryng to run AIM 19.1,during the installation there were no errors relevated and all the pre-requisites were ok.
Im' leaving the information you need below,the screenshot are in italian,if you need me to translate it just let me know
Best regards
OS:Windows 10 Pro 64 bit
Graphic Card:ATI Radeon HD 3200 Graphics,1916 MB
August 28, 2018 at 4:51 pm
tsiriaks
Ansys EmployeeHi AeroX,
Two most common issues that we have seen are:
1. The use of untested/supported graphics card. Please refer to this thread https://forum.ansys.com/forums/topic/what-graphics-card-to-use-on-a-laptop/
You can try updating graphics driver of your current card but it's unlikely to help (if graphics card is the issue). Please check the latest driver from AMD website https://www.amd.com/en/support
2. The use of non-English alphabets in Username and Computer name. I can help you check this if you can launch CMD Prompt then type 'set' (without quote ' ') and put the screenshots in your response here.
Thank you,
Win
August 28, 2018 at 5:51 pm
August 28, 2018 at 9:06 pm
tsiriaks
Thank you for the screenshot. It seems everything is using English language. That's good.
Now it's likely to be the graphics issue. Sometimes, when software crash like this, you can find more information in Windows Event Viewer
Custom Views > Administrative Events
Windows Logs > Application
Look for the events that associated with ANSYS (you can compare the time of occurrence)
Thank you,
Win
August 28, 2018 at 11:00 pm
AeroX
SubscriberIt seems that there are many errors but I don't understand to what they are linked:
AnsysFWW.exe
19.1.0.0
5aca6014
ucrtbase.dll
10.0.10240.17443
59328325
c0000409
0000000000065a0e
16ac
01d43e5ca5c1c398
C:Program FilesANSYS IncANSYS Studentv191FrameworkbinWin64AnsysFWW.exe
C:WindowsSYSTEM32ucrtbase.dll
ba429581-3994-45ef-a6a9-9b0b41409fc0
Can you help me?
August 29, 2018 at 12:36 am
tsiriaks
I've never personally seen issue with ucrtbase.dll , is this the only event that you see in the Event Viewer when the software crash ? Do you see any other event complaining about different dll's ?
With quick google search about that dll , it seems the issue might have something to do with Windows update
(e.g., https://forums.autodesk.com/t5/installation-licensing/windows-10-update-1709-16299-19-inventor-2017-crash-when-open/td-p/7484704
You can try like what mentioned there; however, for ANSYS software, I would recommend to just check any pending Windows update and make sure you install all of them.
Also, go to this directory C:Program FilesANSYS IncANSYS Studentv191prereq , then run every executable one-by-one with 'run as administrator' .
Thank you,
Win
August 31, 2018 at 4:05 pm
JakeC
URCTBASE.dll is a dll that is associated with the VC++ redistributable.
Please use the ProductConfig utility to verify you have all of the Prerequisites installed on your machine.
Start -> Ansys xxx -> Utilities -> Product & CAD Configuration Manager
Click on "Check For required Prerequisites"
Thank you,
Jake
- Workbench error
- Workbench not opening
- License Error
2656
2120
1347
1118
461
