May 29, 2019 at 12:52 pm
info
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHello,
Problem: the cumulative moving average values of the Transient CFD simulation of the drag and lift forces are not assimptotic to the prior Steady State ones.
I set up a parametric study to investigate the aerodynamic resistance of a structural steel angle section in quasi-2d.
For a fixed geometry (L.100.10) I set the wind incidence angle as parameter, extracted the Cd/Cl coefficients and include the results in a chart.
See attached the archived AIM file with results included for the 125°wind incidence angle case.
Please also find some screenshots of model,, mesh and results.
Characteristics:
- wind incidence from 0-180° in 5° steps
- k-e standard RANS model in both Steady/Transient cases (none of the parameters changed in-between)
- boundary layers conservatively set, resulting y+ varies between 0.53-17.13
Other than 2-3 wind incidence angles, the Steady State solution converged ’normal’, see the residual plot attached for the 125°case.
The Cd/Cl coefficients are put in a chart – see attached.
In order to ’validate’ the Steady results, I wanted to make sure about what is obvious in CFD theory, e.g. that the long term transient Cd/Cl values are assimptotic to the Steady state ones.
So by only flipping the solver from Steady to Transient (left every setting as default by ANSYS) I left AIM to run for a 10s Transient run.
Unfortunately, the steady and long time average transient values differs a lot – see the attached time history of the Cd/Cl values.
Questions:
- can you please point out what can be the source of the problem here?
- what turbulence or solver settings (e.g. other RANS models?) should I play around to get more reliable results?
Csaba
May 30, 2019 at 2:09 am
Brian Bueno
Ansys Employeesteelxpert
I will have to inquire with our fluids experts about this. There are several validation models you can test located here. There are about a dozen or so fluid flow examples.
May 30, 2019 at 7:11 am
info
SubscriberDear Brian,
Thank you for your response, I'll check those examples if they can be relevant to my study.
One corrigendum to my original post: the transient chart shows the drag and resultant coefficients instead of drag & lift. Here I uploaded the update.
I am looking forward to the opinion of the fluid experts.
May 30, 2019 at 8:43 pm
Brian Bueno
Here is the response:
Without going through the results, this analysis is using a turbulence model that is not appropriate for the application. KE does not do well with separation of flow as the fluid goes around an object. We recommend using SST, in either steady or transient. Try rerunning these models and then compare the Cd/Cl values.
- Can’t see license on online account
- loss of user settings
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
3744
2573
1793
1236
594
