December 13, 2018 at 6:50 am
December 13, 2018 at 9:21 am
Naresh Patre
Ansys EmployeeHello Kin
The connectivity option between AIM and Workbench is not available with a subscription license, as the Workbench does not currently support a mixed licensing model (subscription for Discovery and floating for Workbench). I would request you to post your suggestion in the Ideas section so that other users can view and vote for it.
December 13, 2018 at 9:46 am
kin
SubscriberHi Naresh Patre Here attaches the video from ANSYS R19 Update that made me try the connectivity. The connectivity function showed in the video started from 1:20. And then, I think it could work due to the licenses showed in the video is a subscription for AIM and the other one is floating for Mechanical ( I guessed that because R19 released the only subscription for Discovery AIM). Thank you.
December 13, 2018 at 11:46 am
Naresh Patre
I am cross-checking with the development team and will let you know.
December 14, 2018 at 4:09 am
Naresh Patre
This workflow is only possible if you have a Mechanical Enterprise license (which also enables Discovery AIM), or a lower level Mechanical license and an AIM Pro License.
December 14, 2018 at 9:59 am
kin
Let me check and know better.
It will work in these conditions below:
1). a Mechanical Enterprise License
2). a Mechanical Enterprise License + ANSYS Discovery AIM License
3). a Mechanical Premium License + ANSYS Discovery AIM License or AIM Pro License
Are those described above correct?
On the other hand, I'd like to know if it will work in the condition:
a Mechanical Pro License + ANSYS Discovery AIM or AIM Pro License?
Thank you.
December 17, 2018 at 5:10 am
Naresh Patre
A Mechanical Pro license plus an AIM Pro license will support this connectivity; and a Mechanical Pro license plus a Discovery Ultimate Enterprise will support this connectivity. As long as both the Mechanical and the AIM licenses are floating licenses the connection will be available.
December 17, 2018 at 5:43 am
kin
Is this function of connectivity feasible for subscription licenses as well?
Thank you.
December 17, 2018 at 8:30 am
Naresh Patre
Ansys EmployeeKin Its currently not possible to use a mix of subscription and floating licenses. You may want to post your suggestion in the Ideas section.
December 18, 2018 at 2:26 am
kin
That's a great help for me to know this informaiton, thank you.
3744
2573
1793
1236
594
