Tagged: ansys-maxwell-electronics, inductance, inductor
March 23, 2022 at 11:16 pm
mh.pial5
SubscriberI designed an air core solenoid with 20 turns and did an Parametric Setup of input current (3A-24A with step size of 3A). I was hoping to get a graph shape like this
March 30, 2022 at 1:44 amNavya C
Ansys EmployeeHi Assuming that you did the initial setup everything correct. Below are the suggestions you can check.
Increase the mesh setting to fine in initial mesh settings.
Use smaller time steps in the analysis setup.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
