November 10, 2020 at 9:22 pm
bsalanitro
SubscriberWould anyone know how to model an air curtain over a large doorway? The air curtain we are trying to model will be using large air blowers that expel air approximately 30 feet. We are not sure if this can be done using Ansys. Any guidance will be appreciated. n -
November 11, 2020 at 11:16 am
Forum ModeratorYou can, and I'd use Fluent for this application. I'd suggest doing the tutorials and also sketch out what you're trying to model, and why.n -
November 17, 2020 at 11:53 pm
bsalanitro
SubscriberWhich tutorials are best for this application?n -
November 18, 2020 at 11:34 am
Forum ModeratorI doubt there's anything specific. I'd look at general air flow and species (no need for reactions) to get the general idea. The AIC courses (Course menu at the top of the page) will explain some of the flow features you'll see. n
- The topic ‘Air Curtain Simulation’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
