Aircraft Analysis
    • Louie Lou
      I hope you are doing very well nowadays. I have a problem, I hope someone did same analysis. I want to do fatigue analysis for an aircraft. As you see in the picture below, there is a graph which is load history for aircraft.
      I will perform a static analysis subject to 1.5G loading for the ground-air-ground condition. Using nCodeDesignLife, I will perform a fatigue analysis of the voltage results obtained from this analysis with variable loadings between 1-1.5G depending on time in ground-air-ground conditions. (TimeSeries Fatigue Analysis)
      What can I do for manoeuvre, taxi and gust? I just want to develop a method. Can you help me, please? I really need your help.
    • Ashish Khemka
      Forum Moderator
      Please do an internet search for the following paper and see if it is of use:
      Dynamic gust, landing, and taxi loads determination in the design ofthe L-1011.
      Ashish Khemka
