airflow over tubes filled with PCM
    • douniaextra1
      Hello everyone,
      I facing a problem in Ansys Fluent.
      I'm simulating a 2D box that contains tubes filled with PCM.
    • subhamdas
      Did you create mesh interface?n
      Use Share Topology in SpaceClaim or create a Multibody Part in DesignModeler, that avoids the need for interfaces. You will need to label the edges as walls though (Named Selections in Meshing). n
