Discovery Import
Discovery Import
Alignment constraints
    • rg
      when the constraints are created if they are not created correctly, the error is reported only in the structure with a yellow triangle.
      Can the error also be displayed at the bottom (where indicated by the arrow)?
      This is because, if you have a structure with many components and the structure is closed, you will not notice if the constraint has created it or not
      Regards
    • Brian Bueno
      Robert
      I will create an enhancement request for this.
    • rg
      Brian Bueno  Hi Brian
      Thank you
