March 11, 2021 at 6:33 am
Rameez_ul_Haq
SubscriberAssume I have 8 physical cores within my machine. I have two separate ANSYS projects which can run independently. I have a RAM of 32 GB. I want the each of the analysis to run using the maximum machine power, so that I can observe the results quicker. So should I allocate 4 cores to each analysis, or can i also allocate 8 cores to each of them?nIf both is possible, then whats going to happen to my RAM usage for each of this?n
Viewing 0 reply threads
Trending discussions
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
Top Contributors
2616
2098
1323
1110
461
Top Rated Tags
