March 18, 2022 at 6:31 pm
apoynter1
SubscriberHi,
I have been using the MQW Edge Emitting Laser example as a base for some simulation work. I have added two additional layers to the laser with in the MODE template that is imported when runFDEmaterial.lsf is run. These are shown in the image below in the orange/brown colour. These were added using the script in the structure group and they are both AlInAs.
March 20, 2022 at 10:48 pmapoynter1
SubscriberI have since managed to fix the error I was having in simulation.
March 23, 2022 at 6:03 pmnuaman98
SubscriberHi there Is the wavelength in the correct region?
Viewing 2 reply threads- The topic ‘Altering Layer Structure of MQW Edge Emitting Laser’ is closed to new replies.
Trending discussions- Ansys Insight: About override mesh in FDTD: its use and settings
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3155
1688
1480
