November 20, 2018 at 3:35 pm
philarama
SubscriberHi there
I have a completed transmission line design created in Altium Designer 18 which I want to simulate in HFSS. Exporting from Altium as a .anf file allows me to import into the Electronics Desktop with all my layer information, dielectric constants etc intact. However, i can't figure out how to simulate in HFSS as Modeller / Import does not accept .anf files.
I can export from Altium as .dxf but then I lose all my layer / materials information.
If anyone can point me in the right direction I will be grateful.
Thanks
Philip
November 20, 2018 at 5:49 pm
slouie
Ansys EmployeeHi Philip,
Best way to bring Altium files into HFSS and preserve padstack definitions, net names, layer thickness and material properties, etc. is to use ODB++ export from Altium. Then in Electronics Desktop, use menu item File>>Import>>ODB++ to bring it into HFSS.
November 20, 2018 at 6:04 pm
philarama
SubscriberThanks slouie - I tried this a couple of hours ago and found all the materials had become vacuum. I will try it again. Cheers.
- Maxwell, HFSS or Q3D?
- Error
2616
2096
1321
1108
461
