TAGGED: ansys, static-structural, structural, structural-mechanics, workbench
May 16, 2022 at 7:42 am
satya_ss
SubscriberMay 16, 2022 at 7:54 amErik Kostson
Ansys EmployeeHi
First we are not allowed to download any attached documents (ansys employees), so perhaps another fellow user can help here.
Secondly we would not be able to advice and look into a paper for you - that is something that you need to do.
for instance one could contact the authors and ask them if they have the properties.
If you then have some question related to how a certain material model in Explicit DYnamics work or how to define a specific material model, then that is something we could perhaps advice on. In explicit we have a foam model called Porosity Crushable Foam that will be of help: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/exd_ag/ds_ex_mat_porocrush.html?q=6.10.1.%20Porosity-Crushable%20Foam
Search the Internet for more info perhaps.
Also I would suggest to look into Ansys LS-Dyna as it has a specific material model for aluminum foams (*MAT_154).
All the best
Erik
Viewing 1 reply thread- The topic ‘ALUMINIUM FOAM MATERIAL’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
