May 16, 2022 at 7:38 am
satya_ss
SubscriberHow to use aluminum foam properties in Ansys Autodyn. basically, I am doing an air blast simulation on the aluminum foam-based sandwich structure. but in the paper, the properties of the foam are not clearly mentioned, please go through the journal paper. for foam,what is EOS, strength model used?
May 16, 2022 at 12:21 pmDavid Mercier
Ansys EmployeeHi, EOS is for equation of state. It's to model the behavior of explosive. More details in this paper for example: https://aip.scitation.org/doi/10.1063/12.0000827
For Al foam, properties are given p344 on your paper:
May 16, 2022 at 3:28 pmsatya_ss
Subscribersir, my question is about aluminum foam .how to make material modeling for aluminum foam used in the core of the sandwich in Ansys Autodyn.
May 18, 2022 at 5:53 amDavid Mercier
Ansys EmployeeYes, in the paper are given stress-strain curves and you could reuse these curves for the material model in Ls-Dyna, using *DEFINE_CURVE and then use this curve's LCSS ID in your material card.
Here a tutorial on Youtube: https://www.youtube.com/watch?v=PxqRRSGh_yg
https://skill-lync.com/student-projects/week-9-material-modeling-from-raw-data-20
www2.ifb.uni-stuttgart.de/composites-analysis/Tutorial3_DynaTutorials1-2/2.Tensile_Test/2.Tensile_test.pdf
May 18, 2022 at 7:35 amsatya_ss
Subscriberbut I need to do it in Ansys Autodyn. I have some problems in the interaction between shell and ALE solver
Viewing 4 reply threads- The topic ‘ALUMINIUM FOAM MATERIAL’ is closed to new replies.
Trending discussions- Adding New Material
- Exothermal reaction kinetics
- Fatigue SN curve
- Curve Fitting – “Error Norm to Fit” expression
- material designer
- Ansys Granta Selector license problem
- Anyone experience in how to model a glass filled polyamide (Nylon)
- Strain Life Parameter
- Multistack layer model
- adding new material in Granta
8808
4658
3155
1688
1478
