AM process with ealive and restart leads to sig$segv error
    • John Miller
      I'm facing some troubles with a AM simulation.
      The Modell is shown below and consists of a heated base plate and a circular extruded volume
      The script of the AM process with ekill and subsequent ealive so that a volume is constantly generated is not difficult. My problem is an embedded restart analysis. I have to enter /post1 in every substep and create a component that includes all contact elements (targe169-conta178) for further processing.
      The component should be used to apply convection bc the nodes on the base plate are not covered by extruded material.
      The APDL snippet is this:
      tintp,,,,1.0
      lnsrch,on
      nropt,full
      thopt,full
      *do,i,1,k,1
      /GOPR
      rescontrol,define,2,k
        cmsel,s,path,node
        cm,Tload,node
        ddele,Tload,temp
        esel,...
        cm,alive,elem
        ealive,alive
        cmsel,s,path,node
        nsel,...
        cm,load,node
        D,load,temp,TL
        nsel,...
        cmsel,...
        cmsel,...
        cm,external,node
        sfdele,external,conv
        *DIM,Rad_Conv,TABLE,7,15,1,,,,11
        sf,external,conv,%Rad_Conv%,Talpha
        allsel,all
        outres,all,all
        Time,...
        solve
        finish
        /post1
        /GOPR
        set,last
        esel,s,enam,,169,178
        nsle,s,active
        !etab,contact_elem,nmis,41
        cm,interface_nodes_bed_contact,node
        finish
        /solu
        /GOPR
        nropt,full
        thopt,full
        antype,,rest
        nsel,...
        cmsel,...
        cmsel,...
        cm,bed_ring_nodes_conv,node
        sfdele,bed_ring_nodes_conv,conv
        sf,bed_ring_nodes_conv,conv,hc,Talpha
      *enddo
      Unfortunately, the simulation is crashing in the first substep of the 2nd load step (1st load step is only for bed heating). The script without /post1 and restart is working just fine.
      The sig$segv is crashing the simulation.
      I guess it has something do to with the database because of all elements of the AM path death and subsequently activated (via ealive).
      Some information is missing regarding the active elements.
      Maybe someone has a clue about how to fix this problem
      With Best Regards
      John Miller
    • Ashish Khemka
      Hi John,
      SIG$SEGV is short for signal segment violation. Technically, it is described as an incorrect use of pointer or a buffer overflow (memory problems). It is a bug, whenever it happens, but it is difficult to relate the cause to any one particular issue. Based on previous call records, it has happened in the past with distributed solver and rezoning, but is not limited to these applications.
      If you are using a distributed solver then please uncheck that option and then run the analysis.
      Ashish Khemka
      • John Miller
        Hello Ashish,
        I was able to get rid of the sig$segv error via removal of the thopt,full line.
        ! tintp,,,,1.0
        !lnsrch,on
        !nropt,full
        !thopt,full
        *do,i,1,k,1
        /GOPR
        The command rescontrol is generating the necessary .rnnn file, but I’m not able to generate the .rdb file within the script. In thermal analysis “restart control” isn’t available via GUI (only in mechanical).
        Below is the error message attached
        Is there a way to perform a restart analysis in thermal transient (with script based .rdb file generation)?
        Best regards
        John
    • John Miller
      Hi Ashish,
      Unfortunately, I knew the issues of distributed solver and tried to run the simulation with only one core aka undistributed solver. The issue is not caused by solver distribution.
      I guess the reason is the element status at the beginning of the first substep of the second step. During the first, heating step, the workpiece elements are all deactivated (via ekill at the beginning of the first load step). In the second load step, the former deactivated elements are activated via ealive.
        finish
        /post1
        /GOPR
        set,last
        nsle,s,active
        finish
        /solu
        /GOPR
        nropt,full
        thopt,full
        antype,,rest
        nsel,...
        cmsel,...
        cmsel,...
      Unfortunately, the simulation is not running anymore without the /post1 trip in every substep (on Ansys WB R2021 R2 Teaching) a few weeks before the model without /post1 script was running just fine.
      Other simulations are running without error.
      I don't understand whats happening here, seems the file is corrupted.
      Best Regards
      John
    • John Miller
      Hello together,
      ! tintp,,,,1.0
      !lnsrch,on
      !nropt,full
      !thopt,full
      *do,i,1,k,1
      /GOPR
      Best regards
      John
Viewing 3 reply threads
