Optical
Optical
Ambient source on Ansys SPEOS
    • hernandez.triana.jl99
      Hi everyone
      I´m learning Ansys SPEOS for simulate a Scheffler type solar colector. I have used the surface source to simulate the sunshine however after reading the user guide I want to use the ambient source instead of the surface soruce but i always receive the same error, so i have some questions about that ¿why is required the source separation ? ¿how can i set source separation on the sensor? and what is the meaning of these numbers (3:392)?
      Thanks.
      José Luis
    • Thomas Martineau
      Hello You can edit the sensor and change the Layer field from None to Sources.
      Best regards
      Thomas
