ambient temperature
    • bxddstl
       Professor, ,I am a novice.I want to do a fluid simulation.:
    • DrAmine
      You can rely on Fluent Expressions to do this kind of ABL profiles. Just look into an exponential formulation for that (you might find for pressure and temperature) and fill in the blanks with the right Expressions. PS: I am not a professor.
      However I did not get your second question so that formulate your request again!
    • bxddstl
      So you are saying that I can add temperature field in Fluent?Does this mean that I don't need the steady-stade thermal system, but only the transient structure systemand fluid flow systemcoupling?
      IfI am right , could you please give me a tutorial on the Expressions of Fluent you said?
      Thank you.
      PS:The second question is actually the first one, I might have a problem with mylanguage expression. I am sorry.
      I don't think there are any tutorials specifically on Expressions. They are covered in the manual, and there are general tutorials in the documentation.
    • bxddstl
      Thank you ,sir.I found it in user s guide.
Viewing 4 reply threads
