3D Design
3D Design
An error in hydrodynamic diffration with static structure
    • YU MINGH
      Hi,guys!
      That happened a really strange question when l'm doing a easy example about hydrodynamic diffracation & static structure.
      I did a Square cube in hydrodynamic diffracation and then i take it connect with static structure to get the cahnge of the Square cube while having the strength of wave.But as a so easy model (which is 10*10*10 m), it shows that i have some question in mesh.
      And then ,when i take it in static stracture, there's a bigger problem that is the hydrodynamic pressure can't work! With a red lightning and no warning.
      So, i want to know how can i do with that? Is there any question?Or i should update ANSYS from 2021R1 to 2022R2?
    • YU MINGH
      It shows in static structure like that.
