3D Design
3D Design
an error occurred while creating the enclosure on ansys
    • IrfanPeratama
      Excuse me, I have an error when enclosing. Does anyone can solve the problem? I've done important geometry from solidwork with the .IGS format. Before that, I did a geometry check. But there are no errors in the geometry. I am very confused now.
      You don't have a volume for the aeroplane: it's a surface body. Look in the Repair tab for the tools.
    • Keyur Kanade
      You should have a solid definition for using enclosure.
      You have only surface body. So you may be missing some surfaces or the faces are not connected.
      Please use different tools like fill, stitch, missing faces etc. to create a solid and then use enclosure.
      Keyur
    • Keyur Kanade
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      Moving to geometry category.
Viewing 3 reply threads
