Ansys Products
Ansys Products
An error occurred while starting the solver module on ANSYS Academic Student 2019 R1
    • luisdamed
      I am getting the message "An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical User Guide for more information" whenever I try to solve any type of Thermal or Mechanical analysis. I already have read all the posts I could find and nothing helped.
      It happens for all the ANSYS projects that I created a year ago using v18 (can't remember exactly which one). My laptop is a Windows 10, 64-bit system and I have plenty of Hard drive space and RAM memory and administrative privileges. I even performed a "soft-reset" and installed version Academic Student 2019 R1 - neither my previous projects or new ones work.
       Can anyone help, please? Thanks
      Luis
    • luisdamed
      Additional facts:
      • When I open the solver directory, there is no Solver.out file.
      • All the folders have only English characters, as well as my user and computer IDs
      • Renaming the C:UsersluisdAppDataRoamingAnsys v193 file to v193.old did not work.
      •  I checked the name references for the loads and boundary conditions and none of them were modified from one release to another.
      • I managed to use FLUENT, though, but I can't open it from the workbench window and have to use the CMD:
                                   cd C:Program FilesANSYS IncANSYS Studentv193fluentntbinwin64
                                   fluent ^-r19.3.0 2ddp -meshing -tm8 -t8
      Here is the output from a CMD license check:
      Microsoft Windows [Version 10.0.18362.476]
      (c) 2019 Microsoft Corporation. All rights reserved.
      C:Usersluisd>"C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_util" -checkout ANS_SOLVER
      2019/11/22 178:09    INFO                Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
      ANS_SOLVER OUT id=DESKTOP-JFRKGAF-LuisD-22052-012666 shared_info=DESKTOP-JFRKGAF-LuisD-22052-012667 is_sharable=yes server=53917@localhost is_academic=yes has_academic_logo=yes max_h_elem=0 max_nodes=0 max_faces=0 max_bodies=0 max_species=0 min_cell_size=0 max_depth=0
              Resolved by Feature: id=183 feature=aa_t_i product=ANSYS Academic Teaching Introductory
      Here is the output when opening Mechanical APDL:
      2019/11/23 105:24    INFO                Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
       2019 R1
       Point Releases and Patches installed:
      FENSAP-ICE 2019 R1
                *****  ANSYS COMMAND LINE ARGUMENTS  *****
        INITIAL JOBNAME              = file
        DISTRIBUTED MEMORY PARALLEL REQUESTED
             2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
          TOTAL OF     2 CORES REQUESTED
        DESIGNXPLORER REQUESTED
        MPI OPTION                   = INTELMPI
        START-UP FILE MODE           = READ
        STOP FILE MODE               = READ
        GRAPHICS DEVICE REQUESTED    = win32
        GRAPHICAL ENTRY              = YES
        LANGUAGE                     = en-us
        INITIAL DIRECTORY = C:Usersluisd
       RELEASE= 2019 R1              BUILD= 19.3      UP20181204   VERSION=WINDOWS x64
       CURRENT JOBNAME=file0  105:26  NOV 23, 2019 CP=      1.109
       /SHOW SET WITH DRIVER NAME= WIN32   ,  RASTER MODE,  GRAPHIC PLANES =  8
       RUN SETUP PROCEDURE FROM FILE= C:Program FilesANSYS IncANSYS Studentv193ANSYSapdlstart.ans
       /INPUT FILE= menust.tmp  LINE=       0
       /INPUT FILE= C:Program FilesANSYS IncANSYS Studentv193ANSYSapdlstart.ans  LINE=       0
       ACTIVATING THE GRAPHICAL USER INTERFACE (GUI).  PLEASE WAIT...
       *** NOTE ***                            CP =       1.656   TIME= 105:26
       The directory "CUsers/luisd/AppData/Roaming/Ansys/ansys19.3" has been
       created to maintain ANSYS settings.
       CUTTING PLANE SET TO THE WORKING PLANE
       PRODUCE NODAL PLOT IN DSYS=  0
       TURN OFF WORKING PLANE DISPLAY
      Honestly, I never tried opening Mechanical APDL before.
    • luisdamed
      •  I managed to solve one of the static structural simulations I made, using Mechanical APDL (thanks to tsiriaks for his advice). However, when reading the results for a transient thermal simulation in Workbench, I get the error
       Your product license has numerical problem size limits, you have exceeded these problem size limits and the solver cannot proceed.
      • I checked the license status from Mechanical APDL and I got this
      ANSYS Licensing Interconnect path is empty.
      Please see the Troubleshooting Section in the ANSYS Licensing Guide for more details.
      ANSYS FLEXlm License path=C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic
      ***** Note: Due to a FLEXlm limitation, all tasks may not be found *****
      ____________________________________________________________________
      ***** ANSYS FLEXlm LICENSE SERVER STATUS: C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic *****
        *** ERROR ***
      lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
      Flexible License Manager status on Sat 11/23/2019 14:49
      [Detecting lmgrd processes...]
      Error getting status: No SERVER lines in license file. (-13,66)
      child killed: SIGABRT]
      But I made these simulations with the same type of Ansys Academic license originally, and everything used to solve without problems.
    • tsiriaks
      For your original issue, that happened with ANSYS Mechanical (in Workbench) , right ? not Mechanical APDL  What if you create a brand-new, test static structural project, does this encounter the same issue ? Please post the screenshot of the all relevant errors.
      For the issue with size limit, see this (this is for ANSYS Mechanical but may give some idea for Mechanical APDL)
      https://forum.ansys.com/forums/topic/mesh-size-errors-even-if-it-should-work/
    • luisdamed
      Please find the screenshot of the error here below. It happens for any simulation I try to solve with Ansys Mechanical. I've tried Thermal, Structural, Eigenvalue, and always get the same result.
      An error ocurred while starting the solver module
    • tsiriaks
      From your Mechanical GUI above, click Tools -> Write Input File , then save it somewhere.
      Open M-APDL Launcher, specify 'ANSYS Batch' in Simulation Environment and specify the path and file name of your Input File, change Working Directory to C:Temp, then click Run. Post any error that comes up from this.
    • DANUSH DATTHATHIREYAN K
      An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.
      help me out
Viewing 6 reply threads
