An Exception has Occured in System Coupling
    • fuad87
      [urgent help needed]
      NOTICE                                |
       | An exception has occurred and has been transmitted to the coupling |
       | participants.  These participants have been disconnected from the  |
       | coupling service.
         HDF5 Exception                         |
       | Origin            : Chart::WriteChartableData->CHDF5Dataset:pen  |
       | Error Code        : 7                                              |
       | Error Description :                                                |
       |   Unable to open Dataset[Solution 2ata Transfer 3:Change:RMS]
       My simulation stopped after 3000 iteration with the above error msg. What to do?
    • Raef.Kobeissi
      coupling between which systems?
    • pgl
      Fuad87 can you share your "System Coupling Log File" that would be help the experts here better diagnose the problem?
      I'll take a stab that you might be running into a disk/folder space issue, as the HFD5 data might be being written frequently and be uncompressed. After 3000 iterations this might be taking up room.
