December 26, 2019 at 7:44 am
December 26, 2019 at 10:32 am
Subashni Ravichandran
Ansys EmployeeHello Duhwan Lee
Could you please try the below suggestions:
- Confirm that you have launched Discovery Live with Administrator right?
- Could you please try deleting all files in the below location and launch a new session of DL to check?%APPDATA%SpaceClaimDiscoveryMaterialLibrary
- Could you also go through points 3, 4 & 5 in this post?
December 27, 2019 at 12:03 am
Duhwan Lee
SubscriberHello Subashni
1. Yes, but this issue in not resolved.
2. I have tried it, but this issue is not resolved.
The MaterialLibrary.xml file was created in %appdata%SpaceClaimDiscoveryMaterialLibrary after 1 and 2.
Please find the attached file. The file is incomplete.
3. There is not nvcuda.dll.
4. It is not solution of this issue.
5. I cannot control settings on AWS.
I copied file from ~ANSYS Incv195scdmMaterialLibraryMaterialLibrary.xml to %appdata%SpaceClaimDiscoveryMaterialLibraryMaterialLibrary.xml.
Then this issue was resolved.
This issue is occured only 2019R3.
Please check it again.
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Dwg export error
- problem to access on the spaceclaim help
- Unexpected graphics error
- Discovery Getting Crashed
- BUG to correct is important
- Error messages running solver
- Critical error
- Discovery Live freezes with multiple load cases while topology optimization
3648
2534
1745
1226
578
