August 30, 2018 at 5:08 pm
Luis Enrique
SubscriberHi! I've tried to simulate a friction stir welding process on ansys workbench 17,
My computer has a i7 7700 HQ, 64 gb ram, but the messeage "an unknow error ocurred during solution" apeared constantly. I already check all APDL codes and the analysis settings. It could be the sub steps i defined in analysis settings? Or the Apdl?
I use a SOLID 226 element in all the geometry, also the contact and target surface was defined in the conecctions window, this area of contact was defined witch these the apdl codes, the contact between plates.
keyopt,cid,1,1
keyopt,cid,4,3
rmodif,tid,14,2e06
rmodif,tid,35,1000
Also the frictional contact between the shoulder and the surface plates was defined like,
keyopt,cid,1,1
keyopt,cid,5,3
keyopt,cid,9,1
keyopt,cid,10,2
rmodif,cid,9,500e6
rmodif,cid,14,10
rmodif,cid,15,1
rmodif,cid,18,0.95
I hope someone could help me
August 31, 2018 at 4:09 am
August 31, 2018 at 1:51 pm
dinhan0394
SubscriberI think you should modify your code.
rmodif,tid,14,2e06
rmodif,tid,35,1000
to:
rmodif,cid,14,2e6
rmodif,cid,35,1000
July 8, 2020 at 8:03 am
SteBir
SubscriberHi you can find an extremely helpful tutorial on Youtube, which reveals the full set-up in Ansys Workbench
This helped me a lot
best regards
Ste
2138
1355
1142
462
