August 13, 2019 at 2:12 pm
Ankush2302
SubscriberHello,
I'm facing a problem in Ansys Solution. I've tried everything and still unable to solve the error.
Text: "An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes."
Association: "Project>Model>Static Structural>Solution"
I'm attaching the worksheet of the solution output.
Please help.
August 13, 2019 at 2:46 pm
jj77
SubscriberSet the number of cores to be used to 2 see (not 3 as it is now) here on how to do this:
https://forum.ansys.com/forums/topic/configuring-from-2-core-to-4-core-processor-for-ansys-18-2/
or
https://forum.ansys.com/forums/topic/error-during-solution/
(For your reference look in the solver out file and search for the word error in the attached file - that will show and explain that it is because of the number of cores used)
August 14, 2019 at 10:06 am
Ankush2302
SubscriberThank you very much for replying but the error still persists. I have attached the latest solver output worksheet for your reference.
August 14, 2019 at 10:41 am
jj77
SubscriberThis is a different error - I would suggest to look on the error message it is very clear just look in the attached file you posted and do ctrl+f to find the word error.
If you cannot resolve then open a new post and close this one.
August 14, 2019 at 7:39 pm
Ankush2302
SubscriberI tried a few things but the error is still unsolved. Can I share the model with you for a possible solution?
August 15, 2019 at 1:55 pm
Mike Rife
Ansys EmployeeAnkush2302
Please paste the Errors listed in the output file as a post here so we can read them. Please do not attach them as a file.
Mike
August 16, 2019 at 10:43 am
Ankush2302
SubscriberI get following error message:
*** ERROR *** CP = 2.219 TIME= 15:23:46
A boundary condition has been imposed on node 552, degree of freedom 1
of the element 3304. Currently, ANSYS does not support such a set-up.
Please avoid boundary conditions on nodes forming the joint element.
A boundary condition has been imposed on node 552, degree of freedom 2
A boundary condition has been imposed on node 552, degree of freedom 3
2138
1355
1142
462
