Feedback
Feedback
Tell us what you love, or suggest ways we can improve
An unknown error occur during the solution. Check the solver output on the solution information
    • gaspar96
      Hi to everyone, I'm a student and I'm using Ansys R2 2021 for my master thesis. I have simulated yesterday my model without any errors but today I found this error and I'm not able to resolve it.
      Can anyone help me please?
    • ANSYS_MMadore
      Did you refer to the solve.out file for details on the error or additional information?
    • gaspar96
      I have got An unknown error occured during solution. Check the solver output on the solution information object for possible causes.
    • ANSYS_MMadore
      If you select the "Solution Information" under the solution, what is in the "Solver Output"?
    • gaspar96
      Solver Output
    • gaspar96
    • ANSYS_MMadore
      There is a FATAL error regarding memory.
    • gaspar96
      How can i resolve this?
    • Aniket
      The error seems to pointing out that there is not sufficient memory to solve the model. It seems like it would need about 2 GB of your total of 4 GB RAM.
      Would it possible to :
      run on a bigger machine with more RAM or
      reduce the mesh size or
      reduce the number of cores used and retry same problem with all other programs closed (especially browsers)
      -Aniket
    • JackWhite
      I don't know about others, but it helped me, thank you very much.
Viewing 9 reply threads
