An unknown error occurred during solution.
    • TechVid
      An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes.
       *** WARNING ***                         CP =       4.703   TIME= 19:462
       The Distributed ANSYS solution does not support SOLID117 elements.
       Distributed parallel processing will be deactivated for this solution.
       *** NOTE ***                            CP =       4.766   TIME= 19:462
       Distributed parallel processing has been temporarily disabled.
       *****  ANSYS SOLVE    COMMAND  *****
       *** TREE GAUGING FOR EDGE ELEMENTS ***
       *** ERROR ***                           CP =       5.547   TIME= 19:462
       *** GAUGE command aborted ***
       NUMBER OF WARNING MESSAGES ENCOUNTERED=          1
       NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1
       ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
      Tried 1) Coarse mesh,
                2)Turning off distribute solution
                3)Virtual topology
                4)Verified carefully the material and setup.
Viewing 0 reply threads
