An unknown error occurred during solution.
    • Flippy
      Hello everyone,
      What should i do if i found a error below:
      Text: "An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes."
      Association: "Project>Model>Static Structural>Solution"
      I look up the output message, I found some error message, but i don't know what should i do...
      Can anyone help?
      Please can you post the message? Staff are not allowed to open attachments.
    • Flippy
      The output message is shown here.
      =================output message============================================
      RELEASE= Release 18.0         BUILD= 18.0      UP20161219   VERSION=WINDOWS x64
       CURRENT JOBNAME=file  133:55  JUN 27, 2019 CP=      0.125
       PARAMETER _DS_PROGRESS =     999.0000000
       /INPUT FILE= ds.dat  LINE=       0
       DO NOT WRITE ELEMENT RESULTS INTO DATABASE
       *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  13.5652778
       TITLE=
       test1--Static Structural (F5)
       SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
        TYPE=STRI  DIMENSIONS=      248        1        1
       PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:Users1155049058Desktopmiddle testAnsys FEA_ProjectScratchScr2180
       SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
       PARAMETER _WB_SOLVERFILES_DIR(1) = C:Users1155049058Desktopmiddle testAnsys FEAtest1_filesdp0SYS-5MECH
       SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
       PARAMETER _WB_USERFILES_DIR(1) = C:Users1155049058Desktopmiddle testAnsys FEAtest1_filesuser_files
       --- Data in consistent NMM units. See Solving Units in the help system for more
       MPA UNITS SPECIFIED FOR INTERNAL
        LENGTH      = MILLIMETERS (mm)
        MASS        = TONNE (Mg)
        TIME        = SECONDS (sec)
        TEMPERATURE = CELSIUS (C)
        TOFFSET     = 273.0
        FORCE       = NEWTON (N)
        HEAT        = MILLIJOULES (mJ)
       INPUT  UNITS ARE ALSO SET TO MPA
       *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE Release 18.0     18.0     ***
       ANSYS Multiphysics
       00000000  VERSION=WINDOWS x64   133:55  JUN 27, 2019 CP=      0.203
                ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
       *********** Nodes for the whole assembly ***********
       *********** Elements for Body 1 "fiber_Line Body" ***********
       *********** Elements for Body 2 "mid" ***********
       *********** Elements for Body 3 "top" ***********
       *********** Elements for Body 4 "btm" ***********
       *********** Elements for Body 5 "spring_line" ***********
       *********** Send User Defined Coordinate System(s) ***********
       *********** Set Reference Temperature ***********
       *********** Send Materials ***********
       *********** Send Beam Properties ***********
       *********** Create Contact "Contact Region" ***********
                   Real Constant Set For Above Contact Is 7 & 6
       *********** Create Contact "Contact Region 2" ***********
                   Real Constant Set For Above Contact Is 9 & 8
       *********** Create Contact "Bonded - fiber_Line Body To mid" ***********
                   Real Constant Set For Above Contact Is 11 & 10
       *********** Create Contact "Bonded - spring_line To mid" ***********
                   Real Constant Set For Above Contact Is 13 & 12
       *********** Create Contact "Bonded - spring_line To btm" ***********
                   Real Constant Set For Above Contact Is 15 & 14
       *********** Create Contact "Bonded - spring_line To top" ***********
                   Real Constant Set For Above Contact Is 17 & 16
                   Real Constant Set For Above Contact Is 19 & 18
                   Real Constant Set For Above Contact Is 21 & 20
       *********** Fixed Supports ***********
       *********** Define Pressure Using Surface Effect Elements ***********
       LIST DATA TABLE  HYPE  FOR MATERIAL      5
       ANSYS Multiphysics
       00000000  VERSION=WINDOWS x64   133:55  JUN 27, 2019 CP=      0.469
                     HYPER EL (HYPE) Table For Material     5
                     Hyperelastic mat. Option - NEO-HOOKEAN
                           1
       Temps     0.0000000e+000
       mu       2.4000000e-001
       d        0.0000000e+000
       ***** ROUTINE COMPLETED *****  CP =         0.469
       --- Number of total nodes = 38522
       --- Number of contact elements = 7770
       --- Number of spring elements = 0
       --- Number of bearing elements = 0
       --- Number of solid elements = 6906
       --- Number of total elements = 16891
       *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  13.5652778
       *************************    SOLUTION       ********************************
       *****  ANSYS SOLUTION ROUTINE  *****
       PERFORM A STATIC ANALYSIS
        THIS WILL BE A NEW ANALYSIS
       LARGE DEFORMATION ANALYSIS
       USE SPARSE MATRIX DIRECT SOLVER
       CONTACT INFORMATION PRINTOUT LEVEL       1
       NLDIAG: Nonlinear diagnostics CONT option is set to ON.
               Writing frequency : each ITERATION.
       DEFINE RESTART CONTROL FOR LOADSTEP LAST
       AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS    0
       DELETE RESTART FILES OF ENDSTEP
       ******************* SOLVE FOR LS 1 OF 1 ****************
       SELECT       FOR ITEM=TYPE COMPONENT=
        IN RANGE        22 TO         22 STEP          1
             1832  ELEMENTS (OF      16891  DEFINED) SELECTED BY  ESEL  COMMAND.
       SELECT      ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
           5622 NODES (OF    38522  DEFINED) SELECTED FROM
           1832 SELECTED ELEMENTS BY NSLE COMMAND.
       GENERATE SURFACE LOAD PRES ON SURFACE DEFINED BY ALL SELECTED NODES
       SET ACCORDING TO TABLE PARAMETER = _LOADVARI61
       NUMBER OF PRES ELEMENT FACE LOADS STORED =       1832
       ALL SELECT   FOR ITEM=NODE COMPONENT=
        IN RANGE         1 TO      38522 STEP          1
            38522  NODES (OF      38522  DEFINED) SELECTED BY NSEL  COMMAND.
       ALL SELECT   FOR ITEM=ELEM COMPONENT=
        IN RANGE         1 TO      16891 STEP          1
            16891  ELEMENTS (OF      16891  DEFINED) SELECTED BY  ESEL  COMMAND.
       PRINTOUT RESUMED BY /GOP
       USE AUTOMATIC TIME STEPPING THIS LOAD STEP
       USE       5 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
       FOR AUTOMATIC TIME STEPPING:
         USE   1000 SUBSTEPS AS A MAXIMUM
         USE      1 SUBSTEPS AS A MINIMUM
       TIME=  1.0000
       ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
       WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
         FOR ALL APPLICABLE ENTITIES
       WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
       WRITE MISC ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
         FOR THE ENTITIES DEFINED BY COMPONENT _ELMISC
       NONLINEAR STABILIZATION CONTROL:
       KEY=OFF
       NLDIAG: Nonlinear diagnostics NRRE option is set to ON.
       The number of files/iterations to be saved for NRRE nonlinear diagnostics has been set to   4
       *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000
       *IF  ANSINTER_                         ( =   0.00000       NE
            0                                 ( =   0.00000       THEN
       *ENDIF
       *****  ANSYS SOLVE    COMMAND  *****
       *** WARNING ***                         CP =       0.500   TIME= 133:55
       Element shape checking is currently inactive.  Issue SHPP,ON or
       SHPP,WARN to reactivate, if desired.
       *** NOTE ***                            CP =       0.516   TIME= 133:55
       The model data was checked and warning messages were found.
        Please review output or errors file (
       FEA_ProjectScratchScr2180file.err ) for these warning messages.
       *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
            --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
       ELEMENT TYPE    1 IS BEAM188 . KEYOPT(3) IS ALREADY SET AS SUGGESTED AND NO
       RESETTING IS NEEDED.
       ELEMENT TYPE    1 IS BEAM188 . KEYOPT(15) IS ALREADY SET AS SUGGESTED AND NO
       ELEMENT TYPE    2 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED. SINCE IT IS
       ASSOCIATED WITH FULLY INCOMPRESSIBLE HYPERELASTIC MATERIALS, KEYOPT(6)=1
       MUST BE USED. THEY HAVE BEEN RESET.
        KEYOPT(1-12)=    0    0    0    0    0    1    0    0    0    0    0    0
       ELEMENT TYPE    3 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
        KEYOPT(1-12)=    0    0    0    0    0    0    0    0    0    0    0    0
       ELEMENT TYPE    4 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
       ELEMENT TYPE    5 IS BEAM188 . KEYOPT(3) IS ALREADY SET AS SUGGESTED AND NO
       ELEMENT TYPE    5 IS BEAM188 . KEYOPT(15) IS ALREADY SET AS SUGGESTED AND NO
       ANSYS Multiphysics
       00000000  VERSION=WINDOWS x64   133:55  JUN 27, 2019 CP=      0.516
                             S O L U T I O N   O P T I O N S
         PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
         DEGREES OF FREEDOM. . . . . . UX   UY   UZ   ROTX ROTY ROTZ
         ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
         OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
         NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
         EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
         PLASTIC MATERIAL PROPERTIES INCLUDED. . . . . .YES
         NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
         GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
       *** ERROR ***                           CP =       0.531   TIME= 133:55
       BEAM188 element number 6276 does not support hyperelastic material 5.
       *** WARNING ***                         CP =       0.547   TIME= 133:55
       Material number 22 (used by element 15060 ) should normally have at
       least one MP or one TB type command associated with it.  Output of
       energy by material may not be available.
       *** ERROR ***                           CP =       0.562   TIME= 133:55
       The step data was checked and there were errors found.
        Please check output or errors file (
       FEA_ProjectScratchScr2180file.err ) for messages.
       *** NOTE ***                            CP =       0.562   TIME= 133:55
       This nonlinear analysis defaults to using the full Newton-Raphson
       solution procedure.  This can be modified using the NROPT command.
       The conditions for direct assembly have been met.  No .emat or .erot
       files will be produced.
       NUMBER OF WARNING MESSAGES ENCOUNTERED=          2
       NUMBER OF ERROR   MESSAGES ENCOUNTERED=          2
       ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
      A N S Y S   S T A T I S T I C S
      Release: Release 18.0       Build: 18.0       Update: UP20161219   Platform: WINDOWS x64
      Date Run: 06/27/2019   Time: 133     Process ID: 2700
      Operating System: Windows 10  (Build: 17763)
      Processor Model: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
      Compiler: Intel(R) FORTRAN Compiler Version 15.0.7  (Build: 20160518)
                Intel(R) C/C++ Compiler Version 15.0.7  (Build: 20160518)
                Intel(R) Math Kernel Library Version 11.3.3 Product Build 20160413
      Number of machines requested            :    1
      Total number of cores available         :    4
      Number of physical cores available      :    4
      Number of processes requested           :    1
      Number of threads per process requested :    2
      Total number of cores requested         :    2 (Shared Memory Parallel)
      GPU Acceleration: Not Requested
      Job Name: file
      Working Directory: C:Users1155049058Desktopmiddle testAnsys FEA_ProjectScratchScr2180
      Total CPU time for main thread                    :        0.6 seconds
      Total CPU time summed for all threads             :        0.6 seconds
      Elapsed time spent pre-processing model (/PREP7)  :        0.2 seconds
      Elapsed time spent solution - preprocessing       :        0.1 seconds
      Elapsed time spent computing solution             :        0.0 seconds
      Elapsed time spent solution - postprocessing      :        0.0 seconds
      Elapsed time spent post-processing model (/POST1) :        0.0 seconds
      Maximum total memory used                         :       37.0 MB
      Maximum total memory allocated                    :     2112.0 MB
      Total physical memory available                   :          8 GB
    • Flippy
      I think the main error is:
      After i change the material type into elastic, it works again
      Possibly an element definition error then? I don't use Mech but do know that some of the models aren't compatible with some of the elements.
Viewing 4 reply threads
