an unknown error occurred during solution. check the solver output
    • hanimamoo
      Hey guys , just having a problem in solving a Baja chassis in Static Sturctural. Mesh is generated but the following error keep coming up. I have solved similar structures in the same devicie without any problem .
      Have attached the solution information. Thanks in advance.
      Text: "An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes."
      Association: "Project>Model>Static Structural>Solution"
    • peteroznewman
      The attached text file is empty.
    • hanimamoo
      Sorry for that. Have uploaded it now. Please have a look at it. Thank you.
    • peteroznewman
      The error is found in the file.
       *** ERROR ***                           CP =      16.875   TIME= 19:56:26
      The normal of target element 353259 is not consistent with the normal
      of target element 353260 in real set 251. Please use the ENORM
      command to correct it.
      *** ERROR *** CP = 17.328 TIME= 19:56:26
      The normal of contact element 353090 is not consistent with the normal
      of contact element 353091 in real set 252. Please use the ENORM
      You could create a Named Selection using the Worksheet to find these two pair of elements.
      It could be that the wrong side of a face was picked in the contact definition.
      It may be possible to flip the face normal in a CAD system.
      Or you could figure out how to use the ENORM command.
    • hanimamoo
      Thanks. WIll try to solve the issue and follow-up here !
Viewing 4 reply threads
