“An unknown error occurred during solution” when using structural
    • GLP28
      Basically, I get this error when trying to run a solution in structural
      According to the solver output, I got the following problems:
      *** ERROR ***      CP =      0.984  TIME= 20:46:17
       Isotropic material 9 has a value of Poisson's ratio of 3 which must be
       greater than -1.0 and less than 0.5 and is therefore not valid for
       isotropic materials.
       Isotropic material 6 has a value of Poisson's ratio of 290000 which
       must be greater than -1.0 and less than 0.5 and is therefore not valid
       for isotropic materials.
       Isotropic material 5 has a value of Poisson's ratio of 290000 which
       Isotropic material 1 has a value of Poisson's ratio of 3 which must be
       Isotropic material 7 has a value of Poisson's ratio of 290000 which
       Isotropic material 4 has a value of Poisson's ratio of 290000 which
       Isotropic material 8 has a value of Poisson's ratio of 290000 which
       Isotropic material 3 has a value of Poisson's ratio of 3 which must be
       Isotropic material 2 has a value of Poisson's ratio of 290000 which
       *** ERROR ***   CP =      1.109  TIME= 20:46:17
       The step data was checked and there were errors found.
      From what I understood, the materials I imported from SW have impossible Poisson Ratio values, however I set them as 0.29, and not as 290000 as Ansys reported. Any solutions?
    • peteroznewman
      On your computer, what is the regional setting for the decimal separator, is it Period, which is used in the USA or is it Comma, which is used in some EU countries? If you use a Comma for the decimal separator, try changing it to Period.
      What version of ANSYS and SW are you using, maybe this bug was fixed in a newer version of ANSYS/SW.
      Regardless of that, you will have to manually edit the materials in ANSYS Engineering Data after import and check each value carefully, making corrections as needed.
    • GLP28
      I tried to change the decimal point on Windows and it didn't work
      However, I managed to fix it by changing the material properties in Engineering Data manually
