TAGGED: #mechanical-#workbench, ansys-mechanical, bolt, bolt-modelling, Screw, threads, torque
August 17, 2023 at 4:23 pm
Christopher Adam
SubscriberHi,
I am trying to analyse a non standard geometry bolt when a preload is applied to see at what load it will fail and evetually determine a suitable torque to prevent bolt failing on assembly. The bolt is a hollow banjo bolt with an M6 thread and 1mm pitch.
Due to its geometry i cannot apply standard hand calcs so hoped i could put a basic simulation together inspired by the paper "Finite element analysis of relationship between tightening torque and initial load of bolted connections"
Is it possible to simulate applying a torque and hence preload to the joint and analyse the bolt? my attempts to replicate the above paper have been nothing short of disasterous.
Even when i supress the model to just the bolt and apply a small displacement to replicate the bolt stretching by 0.1 mm, the stress results are up to extreme with values well into the 1000s of MPa.EDIT:stress reaction is now OK by fixing my materials and applying a cylinderical support with axial and tangential freedom. Still cannot figure out how to apply a working torque -
August 18, 2023 at 12:29 pm
Aniket
Ansys Employee-
August 19, 2023 at 5:38 am
Christopher Adam
SubscriberI have changed materials and applied a cylinderical support and the bolt now at least behave's exactly how i would expect when applying a displacement or preload equivalent force.
I still can't figure out a way to determine torque though, will i need to model the physical threads or is there a way around this seeing as the threads are not the critical area on the bolt?
4468
2957
1429
1322
