August 21, 2019 at 6:51 am
August 21, 2019 at 3:32 pm
HuiLiu
Ansys EmployeeHi ilham,
You can specify whatever frequency you are interested in, eg if you run your experiment at range of 1000-2000 Hz, you can set up the same range in your simulation. However keep in mind the mesh size should change based on your frequency too. You need to have 12 elem per wavelength for linear element and 6 elem per wavelength for quadratic element.
2086
1317
1108
459
