August 23, 2018 at 9:49 am
dallagnol9
SubscriberHello! I had install a ANSYS Student 19.1, But the "analysis Systems in toobox is not available. Some one can help me??
August 23, 2018 at 9:50 am
DrAmine
Ansys EmployeeCreating a new topic on the issue. Can you post a screenshot?
August 23, 2018 at 3:33 pm
tsiriaks
Ansys EmployeeHello dallagnol9 ,
If you don't see modules in the toolbox of analysis systems , it means the software doesn't see the license.
check this
open up CMD Prompt, then issue the following command (this is for default installation path, if you've installed it in a non-default path, you have to change the path accordingly)
"C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_util" -checkout aa_t_i
If your licensing is fine, you should see the output like
"..... INFO Demo license file C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
aa_t_i OUT ....."
Thank you,
Win
August 23, 2018 at 9:36 pm
August 23, 2018 at 9:47 pm
dallagnol9
Hello dallagnol9 ,
check this
aa_t_i OUT ....."
Thank you,
Win
Hello Tisiriaks!!
I executed de CMD like you suggest, the answer is like you wrote. But now, what a need to do?
Thank you!
August 23, 2018 at 10:00 pm
tsiriaks
This means your licensing is ok.
Have you tried Paul's suggestion in this thread https://forum.ansys.com/forums/topic/not-seeing-any-items-in-the-ansys-workbench-toolbox/ ?
If that doesn't help,
do you have any other ANSYS version installed (e.g., 18.x, 19.x, student, commercial, academic) ?
Try resetting configuration, by renaming folder v191 in this directory
%AppData%Ansys (please copy and paste this in the Windows Explorer address bar)
to anything else (e.g., v191.old)
open CMD Prompt and issue this command
set
Then capture the screenshot of the entire output and show it here in the post.
Thank you,
Win
August 24, 2018 at 1:27 am
August 24, 2018 at 3:45 pm
tsiriaks
Ansys EmployeeHi dallagnol9.
In the CMD Prompt, could you issue the command 'set' without the quote '' , then press enter. This would show us the environment variables being set on your machine. Please send the screenshot of the output.
Thank you,
Win
August 24, 2018 at 8:08 pm
August 24, 2018 at 9:51 pm
tsiriaks
Thank you for the screenshot.
The ANSYS related environment variables for 190 are pointing to v18.2 paths for some reason. Not sure if this is the cause of the issue for your v19.1 student version but we can try this
Open CMD Prompt, then copy and paste the following commands (all in the same CMD Prompt window)
set ANSYS190_DIR=
set AWP_ROOT190=
move %appdata%ansysv182 %appdata%ansysv182.back
move %appdata%ansysv190 %appdata%ansysv190.back
move %appdata%ansysv191 %appdata%ansysv191.back
"C:Program FilesANSYS Incansys studentv191FrameworkbinWin64runwb2.exe"
Do you still see blank analysis system in Workbench ?
Thank you,
Win
August 25, 2018 at 1:28 am
August 25, 2018 at 6:20 am
DrAmine
Ansys EmployeeCan you configure the products one again. Just go the installation directory and you will find productconfig.exe unconfigure all and then configure the products. Do you see any error log files in the common folder under Ansys Inc?
August 25, 2018 at 2:06 pm
dallagnol9
SubscriberHello abenhadj,
I find the productconfig.exe, so i click in "unconfigure", it ask to "select the product to unconfigure" but no product appears to select...
I can't see error log files...
Thank you.
August 27, 2018 at 6:26 pm
JakeC
Ansys EmployeeHi dallangnol9,
If you could, please open windows file explorer and paste the following into the address/path bar at the top:
%TEMP%
Now look for a directory called "WorkbenchLogs"
Edit each of those files, and see if there are any errors mentioned. If so, please copy and paste the contents of the file here.
Next paste the following into the windows file explorer address/path bar:
%AWP_ROOT191%commonfilesregistrywinx64
Take a screenshot of the files and directories listed there, and paste into the post.
Lastly, go into the "append" directory, and do the same there. (Screenshot/Post)
Thank you,
Jake
August 27, 2018 at 11:01 pm
dallagnol9
SubscriberHello jcallery
I found 2 error.
Event log opened 25/08/2018 11:05:26 Hora oficial do Brasil
Product version: Release 19.1
Build version: 19.1.0.2018040818
{25/08/2018 11:05:43} [ProjectReplaced
roject] A new project has been created.
{25/08/2018 11:06:12} [System.ObjectDisposedException:System.Windows.Forms] An unexpected error has occurred: Cannot access a disposed object.
Object name: 'InternalUserControl'.
System.ObjectDisposedException: Cannot access a disposed object.
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Control.get_Handle()
at System.Windows.Forms.Control.GetSafeHandle(IWin32Window window)
at System.Windows.Forms.ToolTip.Hide(IWin32Window win)
at System.Windows.Forms.ToolTip.HideAllToolTips()
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnDeactivate(EventArgs e)
at System.Windows.Forms.Form.set_Active(Boolean value)
at System.Windows.Forms.Form.WmActivate(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Event log closed 25/08/2018 11:06:13 Hora oficial do Brasil
x
x
Event log opened 22/08/2018 17:27:49 Hora oficial do Brasil
{22/08/2018 17:28:06} [ProjectReplaced
{22/08/2018 17:28:18} [ProjectReplaced
{22/08/2018 17:40:27} [System.ObjectDisposedException:System.Windows.Forms] An unexpected error has occurred: Cannot access a disposed object.
Event log closed 22/08/2018 17:40:28 Hora oficial do Brasil
x
x
x
Thank you.
August 28, 2018 at 4:27 pm
tsiriaks
Do you have any user access control set ? Can you try turning it off just for a test ?
What if you run Workbench with 'run as admin' ?
Thank you,
Win
August 29, 2018 at 1:56 am
dallagnol9
SubscriberHello tsiriaks,
I just have a password to access the computer. This kind of control did you ask me?
I tried as admin too but is the same thing.
Thank you;
August 29, 2018 at 4:37 pm
tsiriaks
User Access Control (UAC), as shown here
https://www.howtogeek.com/howto/windows-vista/disable-user-account-control-uac-the-easy-way-on-windows-vista/
Can you try disable it and see if it helps ?
Thank you,
Win
August 29, 2018 at 8:42 pm
dallagnol9
I did it but isen't work!
Thank you;
August 29, 2018 at 9:48 pm
tsiriaks
What about this
open elevated CMD Prompt (right click on CMD and 'run as administrator')
then issue the following commands
"C:Program FilesANSYS Incansys studentv191ProductConfig.exe" -silent -prereqs
Wait a few minutes (or you can open up Windows Task Manager and make sure that the process 'productconfig.exe' has stopped running)
"C:Program FilesANSYS Incansys studentv191ProductConfig.exe" -silent -unconfig
"C:Program FilesANSYS Incansys studentv191ProductConfig.exe" -silent -config
then try Workbench again.
Thank you,
Win
August 30, 2018 at 2:09 am
dallagnol9
Before running the first command in the prompt, I took a look at the task manager, but "productconfig.exe" is not running. So when I running the third command in the prompt, the 'productconfig.exe' started running in the task manager.
After the procedure, I tryed the Workbench but isen't show me the analyse sistem yet..
Is a good idea uninstall and reinstall the program, or a old version?
August 30, 2018 at 3:56 pm
tsiriaks
Ansys EmployeeHi dallagnol9 ,
Yes, I think we should try to reinstall now. I don't have any other thoughts on this.
Make sure to run Uninstall.exe under C:Program FilesANSYS IncANSYS Studentv191 with 'run as administrator'
Once this is done, manually delete the C:Program FilesANSYS IncANSYS Student folder
Then, reinstall the products (you can use the same version v19.1) : Run setup.exe with 'run as administrator'
Thank you,
Win
August 30, 2018 at 9:51 pm
dallagnol9
The program show me the following message, but I can't find the "ANSYS, Inc. License Manager"
Installation Complete.
Thanks for choosing ANSYS Products!
***IMPORTANT***
After completing this installation, you need to run the ANSYS, Inc. License Manager installation on each machine designated as a license server. These machines may have been specified during this installation or may have been previously specified.
Thank you.
August 30, 2018 at 11:49 pm
tsiriaks
You can neglect that message. The ANSYS License Manager is the tool used for hosting ANSYS licenses.
Since yours is a free student version, it already comes with its own license. No need to setup (install) ANSYS License Manager.
So, I believe you have reinstalled it. Do you still see blank analysis system ?
Thank you,
Win
August 31, 2018 at 12:49 am
dallagnol9
SubscriberHello tsiriaks.
I have reinstalled, but de Ansys program don't show me analysis system...
Is a idea, uninstall the ANSYS Student Discovery Live... What do you think??
Thank you..
August 31, 2018 at 1:07 am
tsiriaks
Sorry. That's all I can think of at this time. Let's see if others have some thoughts on this.
In the meantime, you can try uninstalling every ANSYS related products/versions, then reinstall only the ANSYS Student version 19.1.
If the issue persists, please resend us the output of the 'set' command in the CMD Prompt.
Thank you,
Win
August 31, 2018 at 2:25 am
August 31, 2018 at 4:02 pm
tsiriaks
Can you try this again
"C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_util" -checkout ANS_SOLVER
Do you see "ANS_SOLVER OUT..... feature=aa_t_i ....... " ?
reissue this command again
If that still doesn't help, can you check your installation package size (right click > Properties) ?
Do you see any install.err or install_licconfig.err under C:Program FilesANSYS IncANSYS Student ?
Thank you,
Win
August 31, 2018 at 8:55 pm
August 31, 2018 at 9:22 pm
August 31, 2018 at 10:28 pm
tsiriaks
The licensing is good.
The installation seems to be fine as well but somehow the software can't read certain information from the installed location (those .xml under
common filesregistrywinx64 ) . The error that you see means it can't find those modules.
Can you go to C:Program FilesANSYS IncANSYS Student , right-click on the 'v191' folder -> Properties , then send the screenshot of it ?
Also, from the ANSYS Student v19.1 installation package, please right-click on the 'ANSYSACADEMICSTUDENT_191_WINX64' (unzipped) folder -> Properties, and send this screenshot.
Thank you,
Win
September 1, 2018 at 1:27 am
September 4, 2018 at 3:45 pm
tsiriaks
Ansys EmployeeHi dallagnol9,
You are using the AIMANSYSACADEMICSTUDENT_191_WINX64 ?
Can you use the ANSYSACADEMICSTUDENT_191_WINX64 ?
Try uninstall everything again. Then, this time use the ANSYS Student package. Do not use the ANSYS AIM Student.
The ANSYS Student package is the third (right-most) package on this page https://www.ansys.com/academic/free-student-products
Once you download the file, the file name should be ANSYSACADEMICSTUDENT_191_WINX64 not AIMANSYSACADEMICSTUDENT_191_WINX64.
Let me know how it goes once you try the ANSYS Student package.
Thank you,
Win
September 9, 2018 at 11:28 pm
dallagnol9
The ANSYSACADEMICSTUDENT_191_WINX64 is complete. the system analysis toolbar is installed and working.(How do I close the poste?)
September 10, 2018 at 7:27 pm
tsiriaks
That's fantastic news ! There should be an option for you to mark what post is the 'answer/resolution' to the issue and that would 'close' the thread (but you can still reply).
Thank you,
Win
September 21, 2018 at 7:06 pm
dallagnol9
Sorry for being late, I marked the solution.
Thank you for help me!!
September 21, 2018 at 9:17 pm
December 17, 2019 at 7:58 pm
December 19, 2019 at 6:00 pm
tsiriaks
Ansys Employeeukijo, create a new thread for your issue and describe what you tried as well as providing the info that was asked for in this thread.
Thanks,
Win
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1349
1118
461
