September 25, 2018 at 2:50 pm
rorti045
SubscriberHello,
I got a temporary license so I can test Ansys and its capabilities. I downloaded the 19.0 academic packages (Multiphysics campus solution), since I have the electromagnetic suite in the same version as well. I installed workbench, but I am unable to use any of the analysis systems included in workbench. At the moment I can only visualize the ones from the electromagnetic suite, which means the integration between these two worked well.
I have attached a picture of the situation. As said before, I have a temporary license so I can test workbench (mechanical and CFD 1 task) + the electromagnetic suite (1 task).
September 25, 2018 at 4:10 pm
tsiriaks
Ansys EmployeeHi rorti045,
For paid academic package like Multiphysics, if you install it and don't see Analysis Systems, this usually means the software couldn't find license for it.
Try this, open CMD Prompt, then issue this command (change your installation path accordingly)
“C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_util” -checkout FLUENT_SOLVER
Please post the screenshot of the output and the command that you run.
Thank you,
Win
September 25, 2018 at 8:27 pm
September 25, 2018 at 11:20 pm
tsiriaks
I don't see the attachment. Can you try to attach again ?
Also the ansysli_util is meant to run as a command in the CMD Prompt, you should copy and paste the below entire line in there
Thank you,
Win
September 26, 2018 at 2:21 pm
September 26, 2018 at 3:16 pm
Ansys EmployeeIf you're on your own machine can you open Start -> ANSYS Inc License Manager -> ANSYS Licence management (as Admin) and one of the options is to add another licence file. If you've already got some of the software working it's probably picked up the EBU key and not the evaluation licence.
September 26, 2018 at 6:18 pm
tsiriaks
Ansys EmployeeAside from the suggestion above to verify that ANSYS License Manager is up and serving CFD license, for the client side, please rename the file 'ansys_student_20171031.lic out of your C:Program FilesANSYS IncShared FIlesLicensing folder
Once you have verified everything is good, try my command again and see if it works. If not, please post the screenshot again.
Thank you,
Win
September 26, 2018 at 10:41 pm
rorti045
SubscriberI tried what rwoolhou's suggestion. It didnt worked.
I think I dont fully understand what you mean by rename the file, I mean I renamed with the ' (apostrophe), but it didnt worked either. I dont know if I should name it differently.
I attached the screenshot from CMD prompt in case you meant 'ansys_student_20171031.lic (with the apostrophe)
Sorry, -
September 27, 2018 at 12:36 am
tsiriaks
Ansys EmployeeSorry, I meant to rename it so that it doesn't end with .lic ; however , whatever you have renamed it has a similar effect to what I want. You can see that the FLEXlm Servers doesn't list that file anymore. This is good.
Let's verify one thing at a time. Start with license on the server side.
From the license server machine (I take it that its hostname is 'Saeed') , open ANSYS License Management Center and see if all status say 'running' .
If so, it might be running fine. Click Display FlexNet License Status and capture the screenshot of the output for me.
If not, something is wrong and the license server is not running. Check if you have installed license file successfully like rwoolhou's suggestion.
Now for client side, open CMD Prompt then type
ping saeed
telnet saeed 2325
If the telnet works, you should see a blank/dark screen. If not, you would see error message.
Note that your machine may not have telnet feature turned on. You can turn it on by typing Windows features in "Search Windows" tool box , then look for "Turns Windows features on or off" and launch this. Then, scroll down to the bottom and check "Telnet Client" > OK
Thank you,
Win
September 27, 2018 at 12:55 am
September 27, 2018 at 12:57 am
September 27, 2018 at 1:04 am
rorti045
SubscriberThis was the result that I got from Workbench when I checked the license. I dont know if this is helpful but I attach it since it might indicate something that we have missed. As a comment, I have already try the re-submission of the license that I was provided by one of your representatives. I opened Ansys License manager > Add license File > Browse > I searched for the .txt file provided > Restart / I have also tried Reread but nothing > Then I get this message
The license file has been installed successfully.
Starting the license manager...
The license manager has been successfully started on desktop-69prrgs.
The new license has been appended to the existing license file. -
September 27, 2018 at 5:21 pm
tsiriaks
The license status shows that the license server is Desktop@#$% something , but your client machine is pointing to 'Saeed'. Now, I'm guessing 'Saeed' is the hostname of your local machine and not the license server machine.
On your client machine,
Launch the Client ANSLIC_ADMIN Utility v1x.x with "run as administrator" > Specify the License Server Machine > Edit Server Machine Specification > in the Hostname 1 box , type the hostname of the server (desktop-69prrgs) > OK
If it's still not working,
try these again
ping desktop-69prrgs
telnet desktop-69prrgs 2325
If telnet doesn't work, it means port 2325 is being blocked between your machine and the license server machine, consult with your IT and ask them to help you open this port.
Thank you,
Win
September 27, 2018 at 6:30 pm
rorti045
SubscriberIt finally worked! To specify the license server machine and its host name was the solution!
Many many thanks for all your efforts, patience and time!
September 27, 2018 at 6:52 pm
tsiriaks
Ansys Employee -
September 28, 2018 at 5:41 pm
September 28, 2018 at 5:42 pm
September 28, 2018 at 7:35 pm
tsiriaks
I just take a look at the license status screenshots that you posted earlier and it seems that license server machine only has licenses for Icepak, SpaceClaim, and ANSYS Electronics Desktop products. It doesn't have Mechanical license.
Do you know if you have Mechanical license on some other server ? If not, and you are interested in evaluating the Mechanical license, I can ask ANSYS Account Manager for your university to reach out to you.
Note: This Mechanical license can't be from the free student version either because that won't work with the paid license for your Maxwell.
Thank you,
Win
September 28, 2018 at 7:44 pm
rorti045
SubscriberHi
So, I requested a license for both Mechanical and Electronics, and one of your account managers gave me the license. They first request my information for the electronics suite and then they used the same information to generate the mecanical license. If you can help me to solve this issue I would appreciate it. Attached to this message I added images of my conversation with one of Ansys account managers.
The first image shows that I was provided a license for EM and then one for Mechanical and CFD. I received two .txt files which according to my understanding, those are the licenses required to be able to use these analysis solvers.
September 28, 2018 at 8:39 pm
tsiriaks
I can't see much of the screenshots but from the license status and your description, I guess the second license file (which is for Mechanical and CFD) hasn't been installed on the license server machine, desktop-69prrgs. Please notify your server admin as well as providing this second license file to them, so they can install it.
Thank you,
Win
- Workbench error
- Workbench not opening
- License Error
2688
2138
1349
1136
462
