Ansys Products
Ansys Products
Analysis systems is missing
    • mimran
      I have installed student version Ansys 2020 R1, Analysis system is missing from the toolbox but available in the toolbox customization box.
       then I tried with Ansys student version 19 again the same issue, I ran CMD command as recommended by ANSYS team but I think in my case its license error.
      Please advice.
    • RushilShah
      I am having the same problem
      Here are some screenshot
      below is the result
    • tsiriaks
      Hi mimran,
      you missed the space in front of "-checkout"
      Hi RushilShah,
      your licensing is fine, what was the name of the installation package that you used ?
      Thanks,
      Win
    • mimran
      Dear Tsiriaks,
      Thank you for identifying mistake, I tried again below is the screenshot but still, it could not resolve the issue. What should I do now?
    • RushilShah
      Dear Tsiriaks,
      DISCOVERY_AIM_STUDENT_2020R1_WINX64 is the name of the installation package that I used.
      Thanks,
      Rushil Shah
    • mimran
      Dear Tsiriaks,
      Any recommendation?
      Please I am looking for a solution to install ANSYS.
    • tsiriaks
      Hi RushilShah,
      Please download ANSYS Student and install it instead. This is the package that allows you to use ANSYS Workbench.
      Hi mimran,
      Your licensing is fine as well, if you didn't install ANSYS Student package, please do so.
      Thanks,
      Win
    • mimran
      Dear Tsiriaks,
      Thank you for your prompt response. I have installed Ansys Student with this I am facing this issue (Missing Analysis systems).
      I just directly installed R12020 but when I couldn't find Analysis systems than I installed 2019 version but still same issue.
      Please advise if I have installed it correctly or do I need to install another package to add with Ansys Student?
      Below are the link and screenshot.
      Looking forward to your response.
      https://www.ansys.com/academic/free-student-products
    • mimran
      Dear Tsiriaks,
      Sorry for disturbing you any comments on installed package
    • tsiriaks
      Hmm, that's odd, try the following command
      move "%appdata%ansys" "%appdata%ansys.old"
      if this doesn't help, please post the content of install.log and install.err file (if exist) from
      C:Program FilesANSYS IncANSYS Student
    • mimran
      Thank you Tsiriaks for your response
      In the folder, I only have the "install" file but I do not have install.err file
      Below is the content of the "Install" file. Kindly assist me.
      Start Installation: Wed Mar 25 08:57:52 2020
      Revision: 2019 R3
      Platform specifics:
          Windows
      Username of Installer: Acer-PCAcer
      User Has Administrator Privileges
      C:UsersAcerAppDataLocalTempans_install_tmp4220instcore.exe -usetempdir C:UsersAcerAppDataLocalTempans_install_tmp4220 -launchdir E:AnsysACADEMICSTUDENT_2019R3_WINX64 -admin
      Initial mount directory:
      Installation Directory:
      Windows x64
      Date verification complete...No conflicts found.
      The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
      This may take a while ...
      Successfully copied prerequisites from media.
      You don't need to install any prerequisites.
      Reading the installation media contents - please wait.
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64framewrkWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64instcoretclCOMMON.TGZ ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64instcoretclWINX64.TGZ ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64commonWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64commoninstallWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configscommonWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cpythextWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cpythnewWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64turbogrdWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configstgWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cfxcomonWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64instutilINSTUTIL.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64instcoretkCOMMON.TGZ ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64instcoretkWINX64.TGZ ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsclientlicensingWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configswbWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64sgchartsWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fwgfxWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addinsWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgwbWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64corewbWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cadscadaisolWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cadscadregistryWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64ekmWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgekmWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgminervaWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64meshingWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64blademodelerWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64apipsrvWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64designmodelerWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64syscplgWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64rsmWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgturbosysWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64secWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64ccmWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cadsacisparaWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64ansysWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64voxelWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsansysWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgansysWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64solverWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64aasWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64dataDATA.GZ ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64apdlAPDL.GZ ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64geomparaWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgmechWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64autodynWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgautodynWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cfxWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgcfxWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configscfxWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64postWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cffWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluentcWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluentsWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluentaWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluentuWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluentpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluentmWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluent2dWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluent2ddpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluent3dWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fluent3ddpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgfluentWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsfluentWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64distcompWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgcfdpostWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64aviewWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsaviewWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64spaceclmWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsspaceclmWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64icemwbWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64electroWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64ecadxltrWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cadsspatialiopWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64cadsspatialWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64acpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addinsacpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsacpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64hlphlpviewerHLPVIEWER.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configshelpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64tpWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64tphdf5WINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64tpzlibWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64tpjreWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64chemkinWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configschemkinWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64forteWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64addincfgforteWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsforteWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64fensapWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsfensapWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64configsansconfigdllWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64studentWINX64.7z ...
        Extraction: E:AnsysACADEMICSTUDENT_2019R3_WINX64licenseWINX64.7z ...
      RSS is disabled
      Performing licensing configuration via the following command...
         "C:Program FilesANSYS IncANSYS StudentShared Filesbinwinx64tclsh.exe" "C:Program FilesANSYS IncANSYS StudentShared FilesLicensinglicadminscriptsLicAdminMain.itcl"  -silentinstallclient -release "2019 R3" -lang en-us
      Licensing configuration has completed.
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigCommon.exe
      Configuring ANSYS TurboGrid ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigTG.exe
      Creating Start menu items for ANSYS client licensing ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigWB.exe
      Running C:Program FilesANSYS IncANSYS Studentv195FrameworkbinWin64Ans.DriverSetup.exe
      Running "C:Program FilesANSYS IncANSYS Studentv195RSMbinAnsConfigRSM.exe" -encodingUTF8
      Configuring RSM...
      Configuring default RSM and ARC Port numbers for 2019 R3 ...
      Done!
      User has Administrator privileges
      Creating Start Menu Shortcut for RSM 2019 R3 Configuration...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Configuration 2019 R3.lnk
      Creating Start Menu Shortcut for RSM 2019 R3 Job Monitor...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Job Monitoring 2019 R3.lnk
      Creating Start Menu Shortcut for RSM 2019 R3 Cluster Monitor...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Cluster Monitoring 2019 R3.lnk
      Creating Start Menu Shortcut for ARC 2019 R3 Configuration...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerARC Configuration 2019 R3.lnk
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigANSYS.exe
      Adding write permissions for Users and Administrators group ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigCFX.exe
      Configuring ANSYS Viewer ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigSpaceClaim.exe
      Configuring ACP ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigACP.exe
      Configuring Help ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigHelp.exe
      ANSYS Internet Doc has been configured.
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigCHEMKIN.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigFORTE.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigFENSAP.exe
      Running "C:Program FilesANSYS IncANSYS Studentv195aisol..commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe"
      Log files is C:Program FilesANSYS IncANSYS Studentv195CADConfigLogsLatestCADConfigurationMgr.log
      MessageLogger.logFilePath is C:Program FilesANSYS IncANSYS Studentv195CADConfigLogsLatestCADConfigurationMgr.log
      ErrorLogger.errorFilePath is C:Program FilesANSYS IncANSYS Studentv195CADConfigLogsCADConfigurationMgr.err
      Prerequisites ..... Configure Success
      SCDM  Workbench  PlugIn ..... Configure Success
      Successfully created file associations.
      Installation Complete: Wed Mar 25 09:139 2020
    • tsiriaks
      This looks good too.
      Can you post the screenshots of what you have in Workbench ? Make sure to post it inline with text and not as attachment
    • mimran
       The analysis system is missing from the toolbox but available in the toolbox customization box.
      Even if I checked all tool nothing appeared in ToolBox.
      Below is the screenshot
    • tsiriaks
      I can't think of other possibility.
      In this WB GUI, if you click Tools-> License Preferences , what do you have ? Please post the screenshot.
    • mimran
      There is nothing inside below is the screenshot
    • tsiriaks
      This just proves that, for some reason, your current Workbench session doesn't see license even though the license checkout command worked.
      Can you try this command again and post the screenshot of the output
      Also, post the output of
      set
      command from CMD Prompt.
      On that Workbench session, click on Help -> About and see the Path to runwb2.exe (or post its screenshot for me)
    • mimran
      I don't know why  Workbench session couldn't see the license.
      You mean I should rename Folder v195 to v195.old?
      I rename the file and run CMD within 2-second new file v195 generated
      Below are both pictures (2 screenshots)
      Then I also Attached is the 2 more screenshots (About Ansys)
    • GuilhermeHybrid
      Hello my friend, i was facing na issue like yours, and what a I did was clicking on View, then Reset Workspace. If Reset WorkSpace doesn´t work, try clicking on Reset Layout. The only difference between mine problem and yours, my screen wasn´t showing noting, the component system neither ACT were appearing...
    • mimran
      Dear Guilhterme,
      I tried and reset both but did not work for me
    • Claudia97
      I have the same problem
    • mimran
      Dear Tsiriaks,
      Any suggestion?
    • tsiriaks
      You didn't try this command correctly
      This is one command. You can just copy-paste into your CMD Prompt. Then, post screenshot of the outcome.
      Also, please post the output of
      set
      command in CMD Prompt.
    • mimran
      Dear Tsiriaks,
      Yes, I tried but still the same issue.
      Kindly check if I executed command properly?
    • tsiriaks
      The last attempt is correct command.
      Now, from CMD Prompt, type the following
      set
      and press 'enter'. Then post the screenshot of its output here.
    • mimran
      Ok
      Below is the screenshot of the "SET" output command
    • RushilShah
      Dear Win,
      It resolved my issue.
      Do I still need to keep Discovery AIM student ?
      I want to simulate Optical system can I do that in ANSYS STUDENT
      Thanks,
      Rushil Shah
    • tsiriaks
      Hi Rushil,
      That's great ! Glad to hear.
      Sorry, I'm not sure about the answer to your question, please create a new thread to corresponding Physics section and ask about this question.
      Hi mimran,
      Now, I think i see the issue.
      You have ANSYS Elastic licensing environment variables set. Where did you get the info to set these ?
      Please unset these two variables unless you need these for some reason
      ANSYSLI_ELASTIC
      ANSYSLI_LCP
      or if you want to do a quick test if that'd help, you can try the followings in CMD Prompt
      set ANSYSLI_ELASTIC=
      set ANSYSLI_LCP=
      "%awp_root201%FrameworkbinWin64runwb2.exe"
    • SherifAshraf
      Hi Tsiriaks,
      I have the same problem and I have tried the suggestion you've mentioned before
      Here are some screenshots
      This is my problem
      and this message is appearing to me each time I'm opening the workbench
      and this message after I did Tools..>License Preferences
      Thank you for your efforts.
    • ALALASUNDARAM
      Dear all,
      I am also facing the problem, and my installation is the same as Mr.Mimran.
      Please help me with what is the final solution worked for this problem?
      Problem: Analysis Systems does not appear in the toolbox.
    • mimran
      Dear Tsiriaks,
      I am not sure why ANSYS Elastic licensing environment variables set in my workbench. I just used link to download ANSYS Student version using below link
      I tried CMD commands but nothing happen kindly check is it correct?
      I am almost lost hope but since there are so many other fellows who are facing same problem might be this thread will be beneficial for all.
      So I am sharing output, please check
    • ALALASUNDARAM
      Dear Tsiriaks,
    • ALALASUNDARAM
      Dear Mimran and Tsiriaks
      Please help me with the steps for getting the Analysis System on the Toolbox of my workbench
      Thanks a lot.
    • ALALASUNDARAM
      Dear Mimran and Win
      Sorry, I have missed noting the below fix, it worked for me well.
      set ANSYSLI_LCP=
      Thanks a lot
    • tsiriaks
      Hi SherifAshraf,
      Your is different, please create a new thread but you can try all of the suggestions provided here.
      Hi ALALASUNDARAM,
      So, the 3 commands work for you ? That's great ! You can permanently remove ANSYSLI_LCP and ANSYSLI_ELASTIC environment variables. You can search online to see how to modify Windows Environment Variables. Then, you don't have to keep launching Workbench with command anymore.
      Hi mimran,
      I'm not sure why that command doesn't see the path for you. But you can go ahead and remove the two environment variables above, the same as I recommended to ALALASUNDARAM, You can then just use the shortcut and not the command to launch Workbench.
      Thanks,
      Win
    • SherifAshraf
    • tsiriaks
      Sorry, I don't monitor that section. You should post it under Installation and Licensing section. But it's ok, I will go there and respond.
Viewing 35 reply threads
